Unit Circle and Other Trig Questions
In summary, when creating a right triangle in a unit circle, the initial side is usually placed on the positive x-axis and the angle is measured counter-clockwise from the positive x-axis. The leg from the terminal side should be drawn to the x-axis for angles between 0 and 180 degrees, or up to the x-axis for angles between 180 and 360 degrees. If you want the cosine of your right triangle to be the cosine of your angle, you should draw to the x-axis. If there are coordinates on the unit circle that are greater than 1 or less than -1, then it is not a unit circle. When theta is equal to pi/2, pi, 2pi, or 3pi
onemic
25
When creating a right triangle in a unit circle how do you know where to place the leg from the terminal side? My textbook and Khan academy don't really explain this and it's just sort of assumed that I'd know. For example, If theta is equal to 135 degrees, where does the leg to complete the right triangle get placed? The y-axis or the x-axis?
Mathematics news on Phys.org
Most people draw the leg to the x-axis, but there is no reason one way would be better than another. In this case ##\frac \pi 2 < \theta < \pi##, so if you drew the leg to the x-axis, your triangle will have an angle at the origin measuring ##\pi - \theta##. If you drew the leg to the y-axis, you would have an angle at the origin measuring ##\theta - \frac \pi 2##. Once you have dealt with the right triangle, be sure to account for your signs; in this quadrant, cosine is negative and sine is positive.
The initial side is usually placed on the positive x-axis. The angle is usually measured counter-clockwise from the pos. x-axis. An angle of 135 degrees would have its terminal side halfway into the upper left quadrant of the unit circle.
Ah, so I can always draw the leg to the x axis? I was getting confused because sometimes the leg from the terminal side would be drawn to the x-axis and sometimes the y axis
That I know, but I'm specifically talking about the leg drawn from the terminal side to complete the right triangle.
It should be drawn down to the x-axis (for angles between 0 and 180 degrees, or up to the x-axis for angles between 180 and 360 degrees.
Likes onemic
Try it out.
##\cos \frac{2\pi}{3} = -1/2##
If you draw the leg to the x-axis, you will have an angle at the origin of ##\pi/3## which has cosine of 1/2.
If you draw the leg to the y-axis, you will have an angle at the origin of ##\pi/6## which has cosine of ##\frac{\sqrt{3}}{2}##.
In any case, you should use whichever method makes the problem simplest, and always, always draw a picture.
Likes onemic
Thanks! This helped clear up a lot.
Another question. There are times where I see a triangle constructed in the unit circle where the terminal side intersects the circle at coordinates greater than 1. I thought that the unit circle has a radius of one and thus any x or y coordinate that intersects the circle can never be greater than 1?
Also when theta is equal to pi/2, pi, 2pi or 3pi/2 what would the opposite and adjacent sides be equal to, since you can't create a right triangle?
Correct. If there are coordinates on the circle that are greater than 1 or less than -1, then it's not a unit circle.
You don't get a triangle with those angles. A better way of thinking of things is that for any point on the unit circle, with coordinates of (x, y), we have ##x = \cos(\theta)## and ##y = \sin(\theta)##. Here ##\theta## is the angle measured from the positive x-axis to the ray that extends from (0, 0) to the point (x, y) on the unit circle. See https://en.wikipedia.org/wiki/Unit_circle.
Likes onemic
Again, you can draw any picture you like as long as it helps you understand the problem.
There might be times where you would draw the right angle at the outside of the circle (radius to tangent line), forcing the radius to be one of the legs rather than the hypotenuse. This method is not generally helpful for determining the (x,y)=(cos theta, sin theta), but might be helpful for other geometric problems.
Likes onemic
Thanks, that cleared everything up
1. What is a unit circle?
A unit circle is a circle with a radius of 1 unit, centered at the origin on a Cartesian coordinate plane. It is often used in trigonometry to establish the relationships between angles and the coordinates of points on the circle.
2. How is the unit circle related to trigonometric functions?
The unit circle is used to define the six trigonometric functions (sine, cosine, tangent, cotangent, secant, and cosecant). The coordinates of points on the unit circle correspond to the values of these functions at various angles.
3. How is the unit circle used to solve trigonometric equations?
The unit circle can be used to find the values of trigonometric functions for any angle, which can then be used to solve equations involving these functions. It is also used to visualize the relationship between angles and the values of these functions.
4. What is the difference between radians and degrees?
Radians and degrees are two different units of measuring angles. Degrees are based on a circle divided into 360 equal parts, while radians are based on the length of an arc on the unit circle. One radian is equal to approximately 57.3 degrees.
5. How can I use the unit circle to find trigonometric values?
To find the values of trigonometric functions at a specific angle, you can use the coordinates of the corresponding point on the unit circle. For example, the sine of an angle is equal to the y-coordinate of the corresponding point on the unit circle.
  • General Math
  • General Math
  • General Math
  • General Math
10K
