Unit of Four Dimensional Space Measurement?
The measurement for the space inside a four-dimensional object is referred to as "hypervolume," which is a generalization of volume for higher dimensions. This concept extends the idea of area in two dimensions and volume in three dimensions to four or more dimensions. The units of measurement can vary, depending on the context and what the four-dimensional object represents. Discussions also highlight that mathematical principles, such as the Pythagorean theorem, apply consistently across dimensions. Understanding these concepts is crucial for grasping higher-dimensional geometry.
Joshuame13
I have been wondering what type of measurement is used to measure the space inside of a four dimensional (space, not time) object. For example, a one dimensional line's distance gets measured, a two dimensional object's area gets measured, and a three dimensional object's volume gets measured, but what type of unit do four dimensional objects get? I am not looking for a specific measurement, such as inches, liters, or square centimeters. What is the category that four dimensional measurements fall under? I have looked all over the internet, but could not find an answer, so I decided Physics Forums looked like a good place to ask.
Four dimensional Lebesgue measure.
It might also be called hypervolume.
Welcome to PF;
I was going to go with "hypervolume".
You got to realize that at some point you will run out of special words for the measure - what if you have 23 space dimensions? Now what do you call it?
Technically the dimensions can have any units though ... so the area of the 2D shape on a v-t graph is a displacement. The meaning of the object, in physics, depends on what it is modelling.
the notion of volume generalizes to higher dimensions in exactly the same way that area extends length and 3 dimensional volume extends area.
I found it instructive to realize that the Pythagorean theorem works in three dimensions exactly as in two. The same applies in four or more.
  • · Replies 27 ·
  • · Replies 37 ·
