Units of length and time in MeV?
  • Context: Graduate
  • Thread starter Thread starter philip041
    Length Time Units
The discussion focuses on converting lengths measured in MeV-1 to SI units, specifically meters. In high-energy physics, the conversion factor is established as 1 MeV-1 = 197 femtometers (fm), or 197 x 10-15 meters. The relationship between energy, mass, and length is defined by the constants hbar and c, which are set to 1 in natural units. The quickest method for conversion is using Google's built-in calculator, which can automatically handle units like eV and MeV.
  • Understanding of high-energy physics concepts
  • Familiarity with natural units (hbar = c = 1)
  • Basic knowledge of unit conversion principles
  • Proficiency in using online calculators for unit conversions
  • Research the implications of using natural units in high-energy physics
  • Learn about the significance of the constants hbar and c in physical equations
  • Explore advanced unit conversion techniques in physics
  • Investigate the relationship between energy and mass in Einstein's theory of relativity
Physicists, students of high-energy physics, and anyone involved in scientific research requiring unit conversions in particle physics.
philip041
How do you convert a length which has been given in MeV ^-1 to SI units?
Energy is mass length^2/time^2 so I guess it;s easy to make the steps of energy - mass - momentum etc... What about length and time?
Cheers
Where have you seen length measured in such units?
Length in MeV^-1 is used in high energy physics.
The conversion is 1=197 MeV-fm.
From what I remember of this stuff, the units are such that
c = 1
hbar = 1
Energy units are MeV​
D'oh! That totally slipped my mind. (Thanks guys.)
So if you multiply (100 MeV)^-1 by hbar*c and then divide by 197 x10^-12??
1 (MeV)^-1 = 197 fm = 197 x 10^-15 m.
So you have said hbar*c=1?
Sorry, I'm lost!
As this is a rather advanced topic, and the OP has made an attempt at wrapping his brain around what's going on, I'll take a stab at setting things up.
In any system of units, we can write
hbar * c = (a number) * (energy unit) * (length unit)​
where
(a number) = just that, some number
(energy unit) = the energy unit of interest
(length unit) = the length unit of interest
Specifically, in the high-energy physics systems of units, we have
(a number) = 1, since we have hbar=c=1 by definition
(energy unit) = MeV
(length unit) = unknown, to be solved for​
The value of hbar*c (or any physical constant for that matter) must be independent of the system of units being used. Therefore
hbar*c = (1.05e-34 J*s) * (3.00e8 m/s) = (energy unit) * (length unit)​
Since we know (energy unit) = 1 MeV, the above equation can be solved for (length unit).
EDIT:
Moreover, that length unit (conveniently expressed in SI units of fm) would be expressed as 1 MeV-1 in the high-energy units system, since
hbar * c = 1,​
by definition, in those units.
Google has a calculator that knows units like eV and automatically puts the answers in SI.
So the quickest way for you is just to use that online calculator and convert it directly.
You just go to Google as if you were going to do a search, and you type some expression into the ordinary Google box and press return.
For example suppose you type this into the box:
hbar*c/eV
The calculator knows what hbar is, and what c is. So it will compute that and tell you
"197.3 nanometers"
Or if you put this in:
2.0 hbar*c/MeV
then it will tell you "3.9 x 10-13 meters".
Cheers I think I have it now!
If you want, you can view it just as a unit conversion.
For example, when you have 10 feet and want to convert it to meters, you multiply by some fixed constant K = 0.3048 meters / foot, to get
10 foot x 0.3048 (meters / foot) = 3.048 meters
When you have 197.3 nanometers (197.3 x 10^(-9) meter) you have to multiply by some other constant K'. We can make K' out of the fundamental constants c and hbar which occur in high-energy physics, by playing around with the units. We note that K' has to have units of energy / meter. Since hbar has units of energy * time and c has units of length / time, we easily see that we need to take K' = hbar c which gives a numerical value of K' = 1.973... × 10^(-16) GeV * meter. Then to express 197.3 nm in energy units, you just compute
\frac{197.3 \times 10^{-9} \text{ meter}}{1.973\cdots \text{ GeV meter}} = 10^{-9} \text{ GeV}
(= 1 eV).
The reason that all of this is actually useful, is for example that we have Einstein's special theory of relativity, which says that it actually makes sense to compare energy and mass.
However, if you are mentally disturbed you could make up new constants, like
p = 1237659,312398 GeV / quack
and express energy, time and length in terms of quacks.
  • · Replies 52 ·
  • · Replies 34 ·
  • · Replies 33 ·
