Universal quantum physics
  • Level: Graduate
  • Thread starter Thread starter A. Neumaier
47 replies · 10K views
Insights Author
TL;DR
a quantum version of Laplace's classical, mechanical universe
Based on the thermal interpretation, I developed a quantum version of the classical, mechanical universe suggested by Laplace over 200 years ago.
Abstract. The purpose of this paper is to propose a quantum version of the classical, mechanical universe suggested by Laplace over 200 years ago. The proposed theory operates fully within the established mathematical formalism of quantum field theory.
The proposed theory unifies the classical and quantum intuition about the macroscopic and microscopic, deterministic and stochastic, local and nonlocal aspects of our world. It entails the best features of several traditional strands of fundamental research, but avoids many of their drawbacks and limitations.
The proposed theory shares
(i) with quantum field theory the local dynamics of quantum fields;
(ii) with statistical mechanics the reduced density operator and coarse graining techniques, but gives them a deterministic meaning for single quantum systems;
(iii) with the statistical interpretation the effective stochastic quantum properties, but explains its deterministic origin;
(iv) with quantum information theory the maximum entropy principle, but gives it an objective meaning;
(v) with the Copenhagen interpretation the importance of classical aspects in quantum experiments, but realized in a pure quantum context;
(vi) with quantum chemistry nonlinear models for mixed quantum-classical dynamics;
(vii) with quantum cosmology the assumption of a universal quantum state, but not assumed to be pure;
(viii) with the thermal interpretation the focus on quantum values for the description of measurements, rather than on eigenvalues;
(ix) with hidden variable theories a nonlocal deterministic dynamics of quantum values, but given by the familiar N-point functions; and
(x) with the many worlds interpretation the unitary dynamics of the universe, but realized in a single world.
In particular, the proposed theory is made compatible with scientific realism by a simple but powerful reinterpretation of some of the formal terms in quantum field theory as in the thermal interpretation. As a result, there is a coherent story to be told about how quantum physics works.
A. Neumaier said:
TL;DR: a quantum version of Laplace's classical, mechanical universe
Is your paper submitted for, or in the process of, publication?
It is finished for submission, and I put it online to get some early feedback before actually submitting it (in a few weeks). So the submitted version will perhaps be a little different.
From the paper:
Universal quantum physics is fully compatible with scientific realism ([92]; cf. Fraser [42]) in the sense that one may take every feature expressible in terms of N -point functions for N = 0, 1, 2, . . . as being real and objective, independent of human perception.
I suspect this is the part of the paper that will be most alien to readers (apart from the algebraic QFT which will be esoteric to readers in general). But I think this is not surprising as this thermal interpretation aspect is also the most novel aspect of the paper.
The article is interesting, but a lot to absorb. Just a few minor points:
You could say a quantum particle has a wave aspect and a particle aspect.
In above sentence "particle" has two different meanings.
In the article the term "particle" is also used for both.
Sometimes for the quantum field; sometimes for the classical everyday particle as in section 8.
I have no good suggestion here, but it is a bit confusing.
page 6
6C. The universal dynamics has no collapse. State reduction (or collapse) of the state of a
physical system is a time-resolved, continuous process.
Would this be equivalent to say that in an experiment when making a measurement with a device (e.g. double slit) then
there is an interaction that impacts the quantum particle causing it to change state?
Do you provide a mechanism within this formalism?
page 8 bottom
basis of this beleiv. -> believe.
page 27
very close to a perticle -> particle or quantum particle
A (classical or quantum) particle is a quantum field concentrated at each time in a small region of space.
I tried to avoid the use of ''particle'' in any other way; if you see other uses, please let me know.
Yes. Without interaction no measurement. And an interaction works in both directions, changing the state of all participants.
This is the measurement problem, analyzed in Section 12. In a semiclassical approximation, this is well understood, see ref. [3], but in a full quantum treatment there are still open problems, discussed there.
Ben vdP said:
page 8 bottom
page 27
Thanks for your close reading!
Morbert said:
From the paper: I suspect this is the part of the paper that will be most alien to readers (apart from the algebraic QFT which will be esoteric to readers in general). But I think this is not surprising as this thermal interpretation aspect is also the most novel aspect of the paper.
I tried to define everything that is not in typical textbooks.
For a single field ##\phi##, the N-point function is simply the map (and in fact for ##N>1## the distribution) defined by all quantum values
$$W(x_1\ldots,x_N):=\langle\phi(x_1)\cdots\phi(x_N)\rangle.$$
This link now contains a significantly expanded version, ready for publication. New additions are (in addition to other small improvements throughout the paper) more details of the connections to cosmology, the similarities and differences to other interpretations of quantum mechanics, a self-contained account of environment-induced decoherence and decoherent histories, and a nearly doubled collection of references.
What is the status (what does it mean) of psi in Schrödinger equation when applicable.
For a physical system in a pure state ##\psi##, the matrix elements ##\langle X \rangle=\psi^*X\psi## may be regarded as providing its properties. For example, if ##X## is an orthogonal projector then ##\langle X \rangle## is a propensity, and can be approximately measured as relative frequency if an ensemble of objects in the state ##\psi## is available.
A. Neumaier said:
For a physical system in a pure state ψ, the matrix elements ⟨X⟩=ψ∗Xψ may be regarded as providing its properties. For example, if $X$ is an orthogonal projector then ⟨X⟩ is a propensity, and can be approximately measured as relative frequency if an ensemble of objects in the state ψ is available.
My understanding is that QM interpretations should give the same results in experiments. It seems as if you are taking about a "different" theory and not an interpretation. I guess I am missing something.
Why does it seem like this to you?
No.
I am using the standard unitary formalism of QM applied to QFT for the whole universe. Then I draw consequences for it's physical subsystems. Since the subsystems are not completely isolated, their dynamics is no longer completely unitary. This leads to decoherence and other well-known effects.
I am not sure about the rule for ai posting but its my understanding also
"do all interpretation lead to the same experimental results
In principle, true
interpretations use the exact same mathematical equations and therefore must lead to identical experimental results. If two frameworks made different testable predictions, they would be considered different theories rather than different interpretations of the same theory.
However, the distinction is nuanced because some frameworks traditionally called "interpretations" actually propose modifications to the math that could be tested with sufficiently advanced technology. "
so it seems TI/UQM is a third kind of interpretation but with a bizarre twist. That is, claiming that what we are measuring is not what we think we are measuring. AS if we are saying that we want to measure the ear length only to find that the contractor is measuring the nose length (or more clearly we don't know what we are measuring). That is unprecedented in science history, that confusion puts a big dent. Now, I understand the overall objective of the idea of universal quantum mechanics which is fine. but I guess what I am trying to say is TI is not about ordinary QM per se but more general.
A. Neumaier said:
No.
Can you analyze this question in your framework
"Lets say this hydrogen atom which is in a superposition (in energy or spin for example) interacts with other atoms, does it affect them with the expectation value or one of it eigenvalues chosen randomly."
selfsimilar said:
I am not sure about the rule for ai posting...
The Physics Forums rules (https://www.physicsforums.com/threads/physics-forums-global-guidelines.414380/) regarding AI are clearly stated:
  • ChatGPT and AI-generated text
    • Posting AI-generated text without attribution is categorically disallowed and will lead to a warning and an eventual permanent ban with continued use.
    • Answering a science or math question with AI-generated text, even with attribution, is not allowed. AI-generated text apps like ChatGPT are not valid sources.
    • Threads about the technology and cultural impact behind AI like ChatGPT are allowed
    • Usage of AI-generated text output in entertainment threads in General Discussion with attribution is allowed.
Can you please cite an example scholarly reference that sets forth an "interpretation" of quantum mechanics that leads to "modifications to the math that could be tested with sufficiently advanced technology"? Thanks.
Yes, objective collapse theories similar to GRW by modifying Schrodinger equation to explain the collapse without measurement but you need high precision equipment not available yet.
https://www.math.uni-tuebingen.de/de/forschung/maphy/personen/roderichtumulka/talks/oxford2021.pdf
edit: from above
As soon as a collapse occurs for one particle in the apparatus, the superposition in the test particle is gone as well. GRW theory agrees with the standard quantum prediction to an excellent degree of approximation. But in principle, the predictions of GRW theory can differ from standard QM.For example, in a double slit experiment in which it takes the particle 300 million years to travel from the double slit to the screen, the interference pattern would disappear. It is not easy to test GRW against standard QM. Dramatic energy increase for much smaller σ values than 10−7 m Slight energy increase for σ = 10−7 m
I am by no means an expert, but I would disagree that objective collapse theories can be called "interpretations" of quantum mechanics. My view aligns with that of the Wikipedia article https://en.wikipedia.org/wiki/Interpretations_of_quantum_mechanics:
"Standard quantum mechanics does not specify any mechanism of collapse; quantum mechanics would need to be extended if objective collapse is correct. The requirement for an extension means that objective-collapse theories are alternatives to quantum mechanics rather than interpretations of it." (underlining added)
As the term "interpretation" is used in this subforum, these theories are not interpretations. They are alternate theories, since they do make testable predictions different from standard QM.
My understanding is that "universal quantum physics" does not make any testable predictions different from standard QM. That would make it an "interpretation" as that term is used here.
In some sense yes , since eigenvalues are used but not as "standard" QM since measurement yields so called Q-expectation. I am not too keen on word characterization but it is surprising because in physical sciences we like to be very clear in what(how) we are examining . Though it is understandable since we are examining very ultra small.
  • Skeptical
Your question is ill-posed. Since this hydrogen atom interacts with other atoms, it is in a mixed state, obtained from the state of this atom + other atoms by forming the reduced density matrix. Thus ''this hydrogen atom which is in a superposition (in energy or spin for example)'' is meaningless.
Moreover, it affects the other atoms according to the mixed terms in the Hamiltonian of the larger system, and not with expectation values or eigenvalues.
But you should at least be keen on using your words precisely enough that one can discuss what you want to say.
The standard QM answer to this would be "neither". To model what you are describing in standard QM (at least non-relativistic QM), you would write down a Hamiltonian for the full system, atom + whatever it is interacting with, and the interaction would be included in the potential term in the Hamiltonian. That is neither of the things you said.
Thanks. Yes the way I wrote "atom" created confusion, I meant another atom. Just thought will be understood by the context. The word keen was about if TI/UQM would be considered an interpretation or something else.
In the Stern-Gerlach experiment discussed on p.15, <P_+> and <P_-> are the propensity for a single silver atom to appear on the left or right spot, respectively. One of the two cases happens, we cannot predict which one, and talking about probability for a single case is meaningless; hence propensity. In an experiment with a large number of silver atoms, these propensities have a probability interpretation, giving the usual probabilities. Thus UQP reproduces the standard predictions for the Stern-Gerlach experiment.
Why?
A. Neumaier said:
Why?
While there is no higher committee to decide. I personally only care for what makes sense to me taking into consideration the consensus, I just expect for people to put forth arguments like your demotion of Born rule which is looked upon as a postulate of QM ( a lot more than less). To my mind that can put the theory in near the red danger area of interpretation or not interpretation.
Is this propensity different from q-expectation.
In the present paper I don't use the term q-expectation. All terminology used in the paper is explained there.
The Born rule is derived in Section 5.2 from a physically simpler and more intuitive postulate, the detector response principle (DRP).
Why does the DRP not make sense to you? It is an extremely well tested statement.
I have heard of many attempts to derive the Born rule but only in the context of the origin of eigenvalue in QM which is not controversial, but TI's case is a quite different take. Moreover, It is quite surprising that after 100 years of studying the subject in many sophisticated research institutes/universities, including Vienna (yours), the researches would be unsure that they are actually measuring eigenvalues with these sophisticated Lasers and what not. Are all these PHD students duping themselves. There must be many papers that look into exactly such questions. Here is a few I dug up, I know it is not a very easy task.
Reference: Levitov, L. S., Lee, H. W., & Lesovik, G. B. (1996). "Electron counting statistics and coherent states of electric current." Journal of Mathematical Physics.
Reference: W. H. Zurek (2003). "Decoherence, einselection, and the quantum origins of the classical." Reviews of Modern Physics.
Reference: Itano, W. M., et al. (1993). "Quantum projection noise: Population fluctuations in two-level systems." Physical Review A.
I haven't studied much about experimentation ( just now you have pushed me to study it more :smile:), so I don't have a definite opinion. But I feel people will look upon it as you have moved the goal post( how different detectors work).
Final note, Personally my limited knowledge and intuition leads me to generally accept your point of view, especially regarding the non locality, since I have alluded to the idea before which looks trivial in QFT, from many points of view.
@selfsimilar Your concerns are somewhat vague. As a starting point: Do you accept that the above approach is consistent with the predictions of textbook QM?
