Unraveling the Mysteries of Faster-Than-Light Travel in Physics
The discussion revolves around the concept of faster-than-light (FTL) travel in physics, exploring theoretical implications, the nature of time, and the existence of hypothetical particles like tachyons. Participants delve into the complexities of relativity, time dilation, and the potential for time travel, while also questioning foundational concepts such as inertial frames.
  • Some participants express confusion about the implications of traveling at or faster than the speed of light, particularly regarding time travel and entropy.
  • There is a discussion on the nature of speed in relativity, emphasizing that speed is relative to an observer's inertial frame, which affects measurements of time, length, and energy.
  • Participants mention massless particles like photons, which must travel at the speed of light, and contrast them with hypothetical tachyons that are theorized to travel faster than light.
  • One participant notes that tachyons, if they exist, would have imaginary mass and discusses the mathematical implications of this concept.
  • Questions arise about the existence of inertial frames, with some participants suggesting that practical assumptions can be made even in non-inertial frames.
  • There is speculation about how FTL travel could allow for sending information to the past, tied to the idea of imaginary time.
  • Participants explore the relationship between speed, time dilation, and the perception of time, questioning how one might travel into the future or the past.
Participants do not reach a consensus on the nature of FTL travel, the implications of tachyons, or the mechanics of time travel. Multiple competing views and uncertainties remain throughout the discussion.
Limitations include unresolved mathematical steps regarding tachyons, the ambiguity of time travel mechanics, and the dependence on definitions of inertial frames. The discussion also reflects varying levels of understanding and interpretation of complex concepts in relativity.
  • #61
ZapperZ said:
But how do you think those two values were obtained in the first place? They are not obtained from any First Principles calculations. If you open the CODATA tables, you'll discover that those values totally depends on knowing what c is, and that causes you to really go in circles if you use them to get c.
This is new to me. If I missed something, please explain me, because I'm here to learn, mostly.
I have always believed we can find epsilon(0) value measuring the Coulombian force between two known charges at a known distance in the void (F=q1*q2/4(pi)epsilon(0)*r^2) or measuring the capacitance C of a plane condenser in the void, knowing S and d (S=area of plate, d = distance from plates):
C = epsilon(0)*S/d.
About mu(0): = 4(pi)*10^-7 by definition.
  • #62
C = epsilon(0)*S/d.
... and you could measure the value of "e", the value of "h", etc.. etc.. in several different ways. Yet, if you look at the standard, international values for these constants, they clearly define a single way in which each these values where obtained.
In the science of metrology, you want to remove, as much as possible, the intrinsic dependence of what you measure on other factors. Measuring the coulombic force isn't trivial! When was the last time were you able to measure such a thing with any degree of accuracy? And how many different assumptions do you have to make regarding your instruments and what you used to measure it?
So you may want to look up how [itex]\mu_0[/itex] and [itex]\epsilon_0[/itex] are measured currently.
Zz.
  • #63
C = epsilon(0)*S/d.
The meter is the SI base unit of length/distance (square that to get the unit of area), and it is defined as "...the length of the path traveled by light in vacuum during a time interval of 1/299 792 458 of a second. " -- http://physics.nist.gov/cuu/Units/current.html
  • #64
I know how meter is defined now. But before this definition, years ago? It was impossible to measure [itex]\epsilon_0[/itex]? We are talking about the mere possibility, not about its precise measurement.
Apart this, I would like to know if you agree with me about the reasoning I made in relation of the other way to define a body's speed.
  • #65
lightarrow said:
This is the concept: you take a train, which holds railtracks attached on top of it. You can impose a certain speed v to this train (measured in the usual way, for example); then you put another train on the first, and impose this second train's speed is still v respect the first one. You can define a new concept of speed, saying that this second train has speed 2*v relative to the ground. But, using Lorentz rule of speed addition, you have, according to the usual definition of speed, that the second train moves at a speed:
v2 = (v1+v2)/(1+v1*v2/c^2) = 2v/(1+beta^2). Repeating the same for a third train on the second and so on, you have v3,...vn. At the limit for n-->infinite, the speed is:
1.infinite, according to the new definition
2. c, according to the usual definition.
I think the concept that lightarrow is struggling to find is that of rapidity, which is defined as
c arctanh (v/c)
A speed of c corresponds to infinite rapidity. Rapidities can be added linearly, but it works only for one-dimensional motion.
  • #66
It goes just beyond the insistance of "precise measurement". It goes down to what we now believe to be a set of fundamental constants of our universe. We now know that for every measurement that we make, we depend on our knowledge of a set of fundamental constants. One or at least one of them is used in ALL measurements that we make.
So if you look carefully, nowhere are the permitivity and permeability of free space considered as fundamental constants. c is. It means that our measurement of both of those values, even your coulombic forces, implicitly depends on the value of c.
Zz.
  • #67
Ok, thank you for your explanation ZapperZ, and the same to the others.
  • #68
the fifth dimension theory
HI
Please can you sent me your e-mail to myin:said_mohamed@hotmail.com
to make it easy for me to sent you small file (the fifth dimension theory) to hear from you about it, thank you.
Greeting feom Finland
Said Mohamed
  • · Replies 21 ·
  • · Replies 120 ·
10K
  • · Replies 40 ·
