Unravelling the Mysteries of Space and Light
  • Thread starter Thread starter AbsoluteChaos
    Light Space
The speed of light is considered finite and constant due to the principles of Einstein's Relativity, which states that nothing can exceed this speed in a vacuum. During the Inflation Period, regions of space expanded faster than light, but this does not violate relativity since it is the space itself that is expanding, not objects moving through space. The concept of 'dark energy' is introduced to explain the universe's current accelerated expansion, requiring a form of energy with negative pressure. The discussion also touches on the relationship between space and matter, questioning how space can expand and carry matter without requiring significant energy. Ultimately, the nature of space, time, and their interaction remains a complex and speculative area of study in cosmology.
AbsoluteChaos
Apololgies in advance for my complete lack of understanding of what are probably a well established facts but I have a few questions which have been buzzing around in my head (a rather empty head at that).
Why is the speed of light finite? Why can't it go faster? Is there an accelleration associated with light or does it just travel at a constant speed?
The reason I ask is that I have read that space can travel faster than light and that during the Inflation Period the Universe expanded very rapidly many times the speed of light. Expansion then continued at a slower and consistance rate until about 5 billion years ago when the expansion started to accerate and is continuing to accerate even today. The main reason given is that as the universe expanded it became less dense and allowed the 'dark force' to overcome the effects of gravity and so allow for accerated expansion.
My suggestion is that space has a natural tendency to expand, in much the same way that light will radiate from a source, and does not require a 'dark force' to make this happen. What we see as a 'dark force' pushing the universe apart, is just space expanding with matter being carried along with the space.
This idea does raise a few question about how space, assuming that it does not require energy to expand (or very little), is then able to move matter, which requires a lot of energy (a awful lot of energy). I have no idea how matter and space are able to interact and even why matter should be carried by space.
I would be gratful if any geniuses out there have the answers, or can completely shoot me down in flames for such a ridiculous idea.
Space news on Phys.org
Thanks for the post AbsoluteChaos. May I just call you Chaos? Thanks.
According to Einstein's Relativity, the speed of light is the ultimate speed in the universe. Why this is the case is not addressed by the theory. One can establish analogies with the speed at which compressional waves travel in different media, and assign permittivities to the vacuum of space, but this doesn't really address the question. Light can change speed when it enters media other than the vacuum. For example, light slows down when it enters water.
During inflation, regions of the universe did indeed recede from each other at a relative speed surpassing that of light. However, objects in these regions are locally at rest -- it is the space between them that is expanding. In General Relativity, observers must obey the laws of Special Relativity locally, which they always do in cosmology.
Lastly, as far the 'dark force' you refer to, I suppose you mean 'dark energy'. Dark energy was proposed to account for the apparent acceleration of the present-day universe. It is not merely a device to facilitate the expansion of space, which happens with ordinary matter and radiation. In order to make the scale factor accelerate, we need a very exotic form of energy with a negative pressure. This is what dark energy is and also what inflation was.
Do we know how much faster than c? Do we know the maximum value of expansion? Is there any upper bound?
The speed at which distant objects are receding is determined by Hubble's Law:
v = Hr
where H is Hubble's constant and r is the distance to the receding object. You can see from this expression that at a special distance, namely c/H, distant objects are receding at superluminal velocities. This is a general property of expansion in a homogeneous and isotropic universe, and has nothing to do with inflation. In an infinite universe (if r is unbounded), then there is no bound on the recession velocity.
Now, the important thing about inflation is that the expansion is accelerating. The difference between non-accelerating and accelerating spacetimes has to do with the behavior of the special distance we identified above: r_H = c/H. How does this distance evolve in time?
\dot{r}_H = -\frac{c\dot{H}}{H^2}
When spacetime is non-accelerating, \dot{H} is negative and larger than H^2 with the result that this distance is increasing at a speed greater than light. That's a bit of a mouthful: the distance at which objects begin to recede at speeds greater than that of light is itself moving away at a speed greater than that of light! The important conclusion is that a galaxy that was moving away from us at v = c yesterday is now moving away at a speed v < c today. In a non-accelerating spacetime, we eventually see all of the universe (given enough time).
During inflation, \dot{H} is again negative but this time smaller than H^2. Now the distance r_H is receding from us at less than the speed of light. A galaxy that is receding from us today at v = c will be moving at least this fast tomorrow. Main conclusion: during inflation there are regions of the universe that we will never see -- the distance r_H marks an event horizon, much like that of a black hole (only in reverse).
EDIT: So, in my post above (#2), I was being a bit unclear about the fact that recession velocities greater than c are not a hallmark of inflation. It's \dot{r}_H that results in inflation having such a dramatic effect on the observable universe.
Is it even proper to speak of it as a "speed" as such? Isn't it a constant?
As far as I have understood inflation, it's a rapid increase of space, i.e. the structural conditions of the universe, rather than anything which is *existing* (in the physical sense).
Speed is constant. The speed of light, c = 3\times 10^8 m/s, is a constant.
Well, I guess it comes down to whether you consider space as existing. And be careful -- time is involved too. I consider spacetime a very real thing in the sense that gravity is a manifestation of it.
Well... I kind of think of space as the canvas and *physicality* as the brushstrokes of colour (or whatever else) that you layer opon it. But you have a point here... I haven't really been thinking about the connection between spatial inflation and *time* in a continuum. Hmmm. Now there's another abyss! Than you very much, like!
bapowell said:
...During inflation, regions of the universe did indeed recede from each other at a relative speed surpassing that of light. However, objects in these regions are locally at rest -- it is the space between them that is expanding...
Edpell, the rate that distances increase depends on the size of the distance. The Hubble law is essentially a percentage increase rule. So longer distances increase more (in km per second terms, or in comparison with the speed of light.)
We don't know the "maximum value" or "upper bound" in terms of speed, because we don't know an upper bound for the size of the universe. And looking back to the beginning of expansion the picture gets somewhat conjectural---there are different inflation scenarios, different assumptions.
In reply to your question "Is there any upper bound?" I think the answer is No, we don't know of any upper bound.
But if you just focus on conditions in the universe TODAY you can get a kind of practical upper bound of around 3c
(not absolute, just for the stuff we can currently see radiation from).
Today the farthest material we can see is the stuff which radiated the CMB radiation. It was originally reddish light like from the surface of a star at a temperature of around 3000 kelvin. And it comes to us with a redshift z = 1090. That's essentially the stretchout factor.
That farthest visible stuff (which has doubtless by now cooled and condensed to make stars planets galaxies etc like our stuff has, so it doesn't look the same as when it radiated the reddish light as a hot gas) is now about 45 billion lightyears away, and receding at a rate of slightly over 3c.
You can calculate this easily for yourself. Google "cosmo calculator" and type 1090 into the z-box. It will tell you the current distance (that goes into Hubble law) is 45 billion ly. (actually 45.5, I'm rounding off the numbers).
But the Hubble distance Powell was talking about, the distance at which things recede at exactly c, is 13.7 billion ly. And the recession rate is proportional. So you just have to divide 45/13.7----it comes to about 3, or 3 and a fraction. So 3c, three times speed of light.
Or google "cosmos calculator" (with an s) for a different one----but then you have to first put in .27 for matter fraction and .73 for cosmological constant and 71 for Hubble rate (the other calculator automatically assumes those standard values, saving bother). The good thing about "cosmos calculator" is that when you put in the redshift number it tells you the recession rate. More trouble setting up but less afterwards.
By upping the redshift you can push "cosmos calculator" back closer and closer to the start of expansion, and you will see the recession speed go higher and higher, and the Hubble parameter (which is now 71 km/s per Megaparsec) go up into the millions. Those calculators embody the standard model that cosmologists use. OK but they are not reliable when you get too close to the start. You can get some qualitative impressions but actually the standard classical model is likey to go wrong very near start and will need some quantum corrections. So it is speculative. Proceed with caution.
But physicists have been able to slow the speed of light down to 38 mph. See http://www.news.harvard.edu/gazette/1999/02.18/light.html
To paraphrase an Einstein question, if you jump off a light wave traveling at 38 mph are you traveling faster than the speed of light?
We're talking speed of light in vacuum, Ray. Those experiments where they get different speeds of light involve some kind of medium. Even water will slow light down to about 3/4 speed. Various types of glass slow it to around 2/3 speed.
What Powell referred to is the speed with nothing else around affecting the speed. Vacuum.
If you allow a medium, then it is easy for things to travel faster than light. In a tank of water you can have electrons traveling faster than light, and they make an eerie glow called the Cherenkov effect. So your thought experiment could be reformulated for someone riding on an electron: "if you are riding on an electron going 8/9 of c in a tank of water, and if you jump off, are you going faster than light?" Yes, because you are going 8/9 c and the speed of light in the medium is only 3/4 c. So you (and the electron you rode in on) are both going faster than light.
c typically means "speed of light in vacuum"
Thanks for the answer, Marcus.
Fundamentally, I think it has to do with causality. All of the fundamental laws of physics of which we are aware of are local: things have to actually be in contact to interact. Long-range forces like electromagnetism and gravity act over distance only by the exchange of mediating particles, photons or gravitons in these cases. So what happens is two particles come together, perform some interaction, then travel apart.
Now, these particles, if they traveled at infinite speed, would lead to non-local behavior: particle A could interact with particle B far away instantaneously, and the laws of physics would no longer be about two things interacting with one another locally. So, there has to be some maximum finite speed at which particles can move. Light happens to travel at this speed in a vacuum, and so we call it the speed of light.
The speed of light is predicated by two fundamental properties of empty space - permittivity and permeability. And, no, this has nothing to do with aether. It has a great deal to do with Coulomb's law.
This is nitpicking a little bit, but I think the causality argument is actually more fundamental: the laws of E&M had to work out at a macroscopic scale such that light waves travel at the speed of light in vacuum because light waves are made of photons, and photons have zero mass. Zero mass objects travel at the maximum speed possible.
Agreed, but, it is fundamentally important to understand that Einstein's relativity is deeply based on Coulomb and Maxwell's theories.
Fair enough. Just saying that he uncovered a richer and deeper reality than Maxwell, Coulomb, and the other physicists involved in developing E&M dreamed of.
I would think that causality is a consequence of a finite speed of light. Not the other way around.
Not necessaraly. Concept of causality is needed to be in place in order to introduce notion of finite speed, or speed at all. I think that it is chicken-egg question.
Yup. Once you have the notion that all fundamental laws of physics are inherently local, that is talking about how things interact when they come into contact with one another, a finite speed becomes a necessary outcropping of that.
Actually, it seems they are one in the same. Can someone remind me why this is being discussed in a physics forum and not the philosophy forum?
Right. But why elevate locality to some bedrock principle?
To be fair, we don't know the most fundamental laws of physics at the current time. All we have are a variety of approximations that have different ranges of applicability. But we can look at what direction our current physical theories are moving, and try to get a handle on the features of the most fundamental theory of physics. One major feature appears to be it must be a quantum theory (which appears to be derivable from Bell's inequality). Another appears to be locality, as the "action at a distance" behavior has dropped away as we've learned more about the long-distance forces.
This could be wrong, of course, but I'm reasonably confident that whatever fundamental theory we finally arrive at, it will turn out to be a local quantum theory.
I follow this. But why can't locality arise from a more fundamental need for a finite speed of information propagation.
The two are basically one and the same statement. What I was saying was something slightly different: that if we have locality, then all "stuff" must travel at or below a certain speed. That is to say, the speed limit "c" is fundamental, and the field equations of electromagnetism are forced to produce waves that travel at this speed because the particles that make up said field have no mass. Put another way, "c" is more fundamental than "\epsilon_0" and "\mu_0".
OK. Perhaps we should all just agree that the following statements:
"Physical theories are local"
"Physical theories are causal"
"Physical theories possesses a maximum, finite speed at which information can be transmitted"
are empirically the same and any attempt to find put a finger on one as being more fundamental than the others is pure speculation.
bapowell
Are you saying that space can expand faster than light, while matter can only travel near the speed of light?
AbsoluteChaos said:
bapowell
Expansion of space isn't a speed. It's a rate (with units of inverse time). So it doesn't really make sense to talk about space expanding faster than or slower than the speed of light.
As for the speeds of objects, relative speeds in General Relativity are only well-defined locally. There is simply no non-arbitrary way to talk about speeds of things far away from one another. So the speed limit in GR reduces to the statement that no object can outrun a light beam. It doesn't say that you won't infer that far-away objects are moving faster than light with respect to you: it can't say that, because you can define the speed of far-away objects however you want! And, in fact, for many of the most obvious ways of estimating speeds of far-away objects, we get speeds much greater than light.
These objects still aren't outrunning light rays around them.
The speed of light is what prevents everything from happening at the same time. Causality is a reasonable alternative explanation.
AbsoluteChaos said:
bapowell
I'm saying that space expands at such a rate that distant objects can reach superluminal recession velocities. See my post #4 above. But as Chalnoth says, they are moving subluminally locally.
The so-called recession velocity is a recession rapidity anyway (the arithmetic sum of infinitely many relative velocities). Rapidities are not limited.
  • #31
Aren't we navigating up another tributary of the great river Anthropogenus?
To resume...
Physics is about interactions.
If the effects of interactions were transmitted instantly then everything would affect everything else.
In that were the case then the Universe would be a seething cauldron of chaos.
It ain't, it's rather well ordered in fact, hence we can exist to observe the locality of interactions.
Thus we require a limited speed of information transfer in order to observe a limited speed of information transfer.
There, I'm stuck on a sandbank.
  • #32
Suppose everytings interacts with everything but the strength of the interaction falls off as R^-2 would we have "a seething cauldron of chaos" then?
  • #33
I may not have been following correctly, but didn't the EPR experiments of Aspect and others since prove that quantum theory is nonlocal?
  • #34
No. You can't transmit information at faster than the speed of light through quantum entanglement. The field equations are also all entirely local.
  • #35
Hmm, well I remembered reading about Bell's proof of this here:
http://plato.stanford.edu/entries/qm-bohm/
In part is says:
One of the achievements of John Bell was to replace the "arbitrary axioms" (Bell 1987, page 11) of Kochen-Specker and others by an assumption of locality, of no action-at-a-distance. It would be hard to argue against the reasonableness of such an assumption, even if one were so bold as to doubt its inevitability. Bell showed that any hidden-variables formulation of quantum mechanics must be nonlocal, as, indeed, Bohmian mechanics is. But he showed much much more.
In a celebrated paper published in 1964, Bell showed that quantum theory itself is irreducibly nonlocal. This fact about quantum mechanics, based as it is on a short and mathematically simple analysis, could have been recognized soon after the discovery of quantum theory in the 1920's. That this did not happen is no doubt due in part to the obscurity of orthodox quantum theory and to the ambiguity of its commitments.(Emphasis mine)
From the references, the John Bell paper seems to be:
Bell, J. S., 1964, "On the Einstein-Podolsky-Rosen Paradox," Physics : 195-200; reprinted in Bell 1987 and in Wheeler and Zurek 1983.
I wasn't able to read the initial paper yet, as I don't have access to the archives, and I'm not sure my understanding is advanced enough to understand Bell's proof, at this time.
So are you in disagreement with the authors here, or are they using the word in a different way than you are?
I was under the impression that pilot-wave theory, or de-Broglie-Bohm theory was a nonlocal hidden variable quantum theory using nonlocal in the same sense of the word that I believe the above cited Stanford article uses it.
  • #36
The apparent non-locality of QM stems from the collapse of the wave function, which never actually happens in reality. There is merely decoherence, not collapse.
  • #37
So are you saying, for example, that in an EPR-type experiment like Aspect's the measurement of one entangled photon doesn't affect the outcome of the other measurement over distances in a way that must be happening faster than light speed?
I realize that there is no way to transmit information using entanglement, but I thought it was pretty clear that there was an instantaneous (or at least superluminal) effect due to the entanglement.
  • #38
Yes.
Perhaps this will explain it:
Imagine, if you will, a emitter which emits entangled photons. Photons traveling in one direction have opposite spin to the photons traveling in the other direction. Now, the spins, when the photons are emitted, are in a superposition of the two available states. But now I go and measure the spin on one side and get a definitive answer: this photon is spin up. I must, if I go back and measure the other spin, get spin down: this is necessitated by the physics of the emitter. The fact that I must measure spin down on one photon if I've measured spin up on the other isn't a manifestation of non-locality, but merely of consistency.
  • #39
The strength of the interaction may fall off as R^-2 and maybe the amount of interaction will rise as R^3 (on a large enough scale)
If my understanding is correct (a very dubious prospect mostly) this is the basis of why the inertia we experience is the fruit of our (non-instantaneous) interaction with the furthest observable objects in the Universe. The further we look, the more there is to interact with.
