Does Loctite Cause Helicoils to Fail During Screw Removal?
  • Thread starter Thread starter PhillipK
Using Loctite on screws in M2.5 Helicoil STI holes can lead to the Helicoil being removed along with the screw, creating significant logistical issues for customers needing repairs. Recommendations have been made to switch to locking Helicoils, but these suggestions have been ignored. Documentation to support the position against using Loctite is lacking, despite Helicoil's verbal advice. Some users suggest quoting Helicoil's recommendations or conducting tests to demonstrate that Loctite is unnecessary. Ultimately, the discussion highlights the need for better communication and adherence to best practices in screw installation.
PhillipK
We have a customer who insist's on applying loctite on screws before installing them in standard M2.5 Helicoil STI holes. The problem is if they need to remove the screw the Helicoil comes out with the screw. We have recommended that they make a change to the drawing to call out for locking Helicoils but it would appear they have ignored this advise. We end up re-installing new Helicoils which is a logistical nightmare as the customer is in singapore.
Question: Is there any documentation I can get my hands on to convince them that Loctite should not be used on Helicoils they may need to be removed at some point in the future. I have contacted Helicoil and while they will tell you not to do it they have no documentation to support the position, they just make the same recommendation that we do, to switch to locking Helicoils.
Any help would be welcome
Phillip
Quote Helicoil's recommendation, or commission a test to prove that Loctite isn't necessary.
use loctite thread locker RED 271 to permanently lock the helicoil
use loctite thread locker Blue 242 on bolt as this is used where disassembly to service is required but still want to "lock " the bolt in
Had my central air system checked when it sortta wasn't working. I guess I hadn't replaced the filter. Guy suggested I might want to get a UV filter accessory. He said it would "kill bugs and particulates". I know UV can kill the former, not sure how he thinks it's gonna murder the latter. Now I'm finding out there's more than one type of UV filter: one for the air flow and one for the coil. He was suggesting we might get one for the air flow, but now we'll have to change the bulb...
  • · Replies 38 ·
