Use Stokes's on Line Integral to Show Path Independence
Stokes's theorem demonstrates that the line integral of the vector field F over a curve L depends solely on the endpoints of L, not the path taken. By considering two curves L and M with the same endpoints, a closed curve C can be formed, allowing the application of Stokes's theorem. The key is to compute the curl of F and show it is the zero vector, indicating that the integral over the closed path C is zero. This leads to the conclusion that the line integrals over L and M must be equal. The discussion also touches on scenarios where the curl may not be zero, yet similar properties could still hold under specific conditions.
sikrut
Use Stokes's theorem to show that line integral of ##\vec{F}(\vec{r})## over an curve ##L##, given by ##\int_L \vec{F}(\vec{r}) d\vec{r}##, depends only on the start and endpoint of ##L##, but not on the trajectory of ##L## between those two points.
Hint: Consider two different curves, ##L## and ##M##, say, which share a common start and endpoint. Construct from them a closed curve ##C## to which Stokes's theorem can be applied.
$$\vec{F}(\vec{r}) \equiv [F_x(\vec{r}), F_y(\vec{r}), F_z(\vec{r})] = [2z^2, 3z^2, (4x+6y)z] \rightarrow where \rightarrow \vec{r} \equiv [x,y,z].$$
First, you need to remember that Stoke's theorem says that $$\iint\limits_S curl( \vec{F} ) d \vec{S} = \oint\limits_C \vec{F} d \vec{r}$$ You need to compute ##curl( \vec{F})## and show that it is the zero vector. This would mean that any closed line integral will be zero. This makes the integral over the path ##C## zero, which forces the two line integrals ##\int\limits_L \vec{F} d\vec{r}## and ##\int\limits_M \vec{F} d \vec{r}## to be equal.
Good Luck!
It's not necessarily the curl of F that needs to be zero, but the integration over the circumscribed area of the curl dotted into an element of normal area.
this is true, but I think if the curl is nonzero at some point then you could find a surface that makes the surface integral nonzero (you would need some sort of continuity assumption to prove this). Since this problem is talking about an arbitrary curve, L, I believe the only possibility is to show that the curl itself is zero.
I could imagine, however, a problem stated "for an arbitrary path on the surface, S, show that..." in which the curl isn't zero, but the same property holds.
Consider a single-turn copper coil with a mixture of ∂B/∂t of both polarities thruout its area. Curl of the E field = -∂B/∂t could be nonzero everywhere within its planar area but ∫curl E*dA = 0 is entirely possible, so that the circulation of E (the emf) around the coil would be zero too.
Of course, what you say is entirely correct for a lamellar field like gravity or electrostatic E field.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
