Using a bigger battery for a computer UPS?
  • Thread starter Thread starter anjaykm
    Battery Computer
Upgrading to a larger battery, such as a 12V 100 Ah, can indeed extend the backup duration of a UPS, but it raises concerns about compatibility and safety. The original UPS battery is likely a deep discharge gel type, which can handle deeper discharges than a typical car battery, which should not be discharged below 50-60%. Charging a larger battery may exceed the UPS's designed charging rate, potentially damaging the charger. Additionally, using multiple batteries in parallel does not increase voltage but can increase capacity, while proper fusing is essential to prevent dangerous short circuits. Careful consideration of battery type and UPS specifications is crucial for safe and effective modifications.
anjaykm
Hi guys,
I m considering changing the battery to a bigger one so as to increase the backup duration.
The battery that came with it is 12V 7.5 Ah. The battery I m planning to put is a 12 V 100 Ah. Now my question is, will the big battery increase the standby duration without overloading and damaging the hardware in the UPS.And will it charge the bigger battery?
I have an APC Back-UPS ES 500 VA,300 Watts.And having the battery externally is what I had in mind.Thoughts please ?
Yes it's a common way of making a decent backup power. Take the electronics from a UPS and hook up a whole bunch of cheap car batteries in parallel.
A couple of important points - the battery supplied with the UPS is probably a deep discharge gel battery, it can be discharged to within say 10-25% of empty without damage. A car battery can only be discharged to 50-60% repeatedly.
The charging rate will be optomised for the sealed batteries but an unsealed car battery can cope with a faster rate. If you are using an unsealed battery make sure it is well ventilated - explosive hydrogen is given off when it charges,
what exactly do you mean discharge to 10-25 % without damage and 60 % in case of a car battery.CAn you elaborate on that if you don't mind ?
When I go for multiple batteries, will the input voltage double in both parallel and serial connections assuming I connect two batteries in this case ?Will this also increase the watts that the UPS can handle ?
Car batteries are not good for medium or low current applications where the current is drawn over a long period of time. They can suffer damage if discharged too deeply. They are really for starting engines. Leisure batteries (for caravans - trailers) are more suitable.
High current batteries are pretty dangerous. If you get a short circuit a heck of big current can flow and there may be a blinding flash like an arc welder. You MUST have proper fusing and/or a circuit breaker. A larger battery might demand a hefty charging current and blow a charger which has been designed for a smaller battery.
I am trying to understand how transferring electric from the powerplant to my house is more effective using high voltage. The suggested explanation that the current is equal to the power supply divided by the voltage, and hence higher voltage leads to lower current and as a result to a lower power loss on the conductives is very confusing me. I know that the current is determined by the voltage and the resistance, and not by a power capability - which defines a limit to the allowable...
  • · Replies 56 ·
54K
  • · Replies 16 ·
  • · Replies 16 ·
13K
