Calculating Force and Efficiency of Fans Using Airflow Measurements
  • Thread starter Thread starter Trebor0808
    Airflow Force
The discussion focuses on measuring airflow to calculate the force and efficiency of different fans. Suggestions include using a pendulum method to measure displacement and weight, along with applying the thrust equation from axial fan design. Participants emphasize the importance of understanding thrust as the change in momentum of the air rather than a direct force of airflow. Additionally, accurate measurements of air velocity and energy consumption are crucial for determining efficiency. Overall, the conversation highlights the need for precise calculations and methodologies in fan efficiency experiments.
Trebor0808
Hi,
I am doing an experiment where I am measuring the airflow readings (m/s) of different fans. I then was hoping to use this to work out the force and then from that the power to compare the efficiencies of the different fans. I was wondering if anyone had any suggestions for what equations to use to find the force from the air flow as I haven't found any that are particularly helpful?
Thanks.
Better. Suspend the fan as a simple pendulum and measure the displacement and weight just like in physics lab.
Trebor0808 said:
Hi,
Thanks.
Look at Pitot & Bernoulli
what do you mean by force of an airflow? it does not exist something like that.
If u mean the thrust produced by the fan i quote pendulum approach! :p
The power or force is equal to the change of momentum of the air. The efficiency is how much energy is being used to change the momentum.
Measure accurately velocity in and out and the energy consumption of the fan.
I do not have a good working knowledge of physics yet. I tried to piece this together but after researching this, I couldn’t figure out the correct laws of physics to combine to develop a formula to answer this question. Ex. 1 - A moving object impacts a static object at a constant velocity. Ex. 2 - A moving object impacts a static object at the same velocity but is accelerating at the moment of impact. Assuming the mass of the objects is the same and the velocity at the moment of impact...
13K
  • · Replies 17 ·
