Using ampere's law for a circular loop
6 replies · 5K views
Essence
Sorry to bother you guys,
I've heard that Ampere's Law is either ineffective for calculating the B field due to a circular loop or needs some modification (I wasn't sure which).
I'm trying to figure out why this doesn't work so I can get a better understanding of Ampere's Law. I have attached a picture of two loops (probably trivial). The inner loop is the one with a current the outer loop is the surface I chose for Ampere's Law.
I know you guys have to deal without a lot of dang so I hope I haven't imposed too much.
Thanks,
(integral) Bdl = u * I
[/B]
To be more concrete about this whole thing imagine I had a looped wire with current I. I will now use Ampere's Law. First I will choose a surface which is another circular loop that contains the first loop. Now I will use:
(integral) B dl = u * I. Since each piece of current in the loop has another piece of current going in the opposite direction (it's a circle after all). I should get an I enclosed of 0. This would suggest the B field is zero (which I could justify using the Biot-Savart law isn't true). For space I will not do that here; that's a number plugging game.
Not so much a number game as a vector game.
It is not so that ##\oint \vec B\cdot \vec{dl} = 0\quad \Rightarrow \quad |\vec B| = 0 ##.
I think I get it. Since the B fields may be opposite at some points if I integrate the B fields over the surface I will get zero. But if I'm to find a specific B field at a location since B is not a constant function (it flips signs) I can't just divide by 2* pi * r and get 0. This is because the result of taking the integral is not B * 2pi * r (again because B is changing and so can't be treated like a constant).
I think you have the wrong picture of the situation
Re pictures: Perhaps google "magnetic field of current loop" and look at some of the pictures.
Re Ampere's law: the integral is not a surface integral but a line integral: ##\vec {dl}## is a little section of the wire, so to say.
(But, considering you do write "the result of taking the integral is not ##B\ 2\pi r##", it appears you have the right intention but just use the term "integrate the B fields over the surface" a little sloppy ? -- "B field over the loop" would be better)
Combining the two: From the pictures and the circular symmetry you can see that at the location of the outer loop wire ##\vec B## is in fact a constant, and the direction is perpendicular to the plane of the two wire loops. No flipping sign, no "opposite at some points".
Since ##\vec {dl}## is in that plane, the inner product ## \vec B\cdot \vec{dl} = 0 ## and that is what makes the ##\oint\ ## come out as zero.
Ok.
(Just confirming)
$$\vec{B}\cdot\vec{dl}$$ will equal zero (because we're taking a dot product of perpendicular vectors) but this does not mean B equals zero. Ideally we want to choose a loop where B is in the same direction as dl such that we can just divide by the distance over which the line integral is taking place to get B.
Sorry about earlier; that was very very sloppy. I did mean line integral rather than surface integral, and I had temporarily assumed that the B field switched from into the page to out of the page depending on what side of the loop you were on. I didn't actually check this with greater care because I assumed that that was the only thing that could cause issues, but I hadn't considered the dot product.
Thanks,
(can't delete posts)
I think you are doing just fine. Ok you are !
