Using an expanded power series to estimate
The discussion focuses on expanding the function f(x) as a power series and using that expansion to estimate the value of 7 / (1.1)^(1/4) to three decimal places. The initial power series expansion provided is critiqued for not correctly applying the nth power of x, leading to inaccuracies in the calculations. Participants emphasize the importance of including sufficient terms in the series to achieve the desired precision, with calculations showing that using two terms plus the zero term is adequate for three decimal places. Ultimately, the corrected calculation yields an approximation of 6.83518, which aligns closely with the actual computed value. This highlights the significance of careful term selection in power series approximations.
NastyAccident
(a) Expand f(x) as a power series
f(x)=\frac{7}_{\sqrt[4]{1+\frac{x}_{14}}}
Which I converted to...
7 - \frac{1}{8}*x + \sum^{\infty}_{n=2}7*(-1)^{n}*\frac{1*5*9*...*(4n-3)}{4^{n}*n!}*(\frac{x}{14})^{n}
(b) Use part (a) to estimate 7 / (1.1)^(1/4) correct to three decimal places.
Knowledge of Taylor & Maclaurin Series
7 - \frac{1}{8}*(1.1) + \sum^{\infty}_{n=2}7*(-1)^{n}*\frac{1*5*9*...*(4n-3)}{4^{n}*n!}*(\frac{1.1}{14})^{n}
=0.981268
Though, I think this is more on the right track:
1.1=1+x/14
.1=x/14
1.4=x
7 - \frac{1}{8}*(1.4) + \sum^{\infty}_{n=2}7*(-1)^{n}*\frac{1*5*9*...*(4n-3)}{4^{n}*n!}*(\frac{1.4}{14})^{n}
=0.976454
As always, any guidance will be appreciated and thanked =)
NastyAccident
1.1=1+x/14
.1=x/14
1.4=x
=0.976454
I am fairly sure that part a should be more difficult than part b.
you have expanded about x=0, so the 2nd part where you subtitute x=1.4 into your formula is the correct way to get
\frac{7}{(1+x/14)^{1/4}} = \frac{7}{(1.1)^{1/4}}
however I'm not sure how you get your value, you series look reasonable though i haven't checked it 100%...
checking the value with a calculator I get ~6.8. You need to keep adding terms until the 3rd decimal place is stationary
consider the first 2 terms
7 - (1.4)/8 = 6.825
each term will be close to an order of magnitude less than the previous (as it has (x/14)^n) which should give you a hint as too how many terms are required...
Hehe, late at night part a. is ten times easier than part b.
7 - (1.4)/8 = 6.825
7-[7*(1)/(4*1!*14)](1.4) = 6.825
7-[7*(1)/(4*1!*14)](1.4)+[7*(1*5)/(4^2*2!*14^2)](1.4) = 6.83281
7-[7*(1)/(4*1!*14)](1.4)+[7*(1*5)/(4^2*2!*14^2)](1.4) - [7*(1*5*9)/(4^3*3!*14^3)](1.4) = 6.83239
7-(1/8)(1.4) + 7(5/(4^2(2!)*14^2))(1.4) - 7((5*9)/(4^3(3!)*14^3))(1.4) + 7((5*9*13)/(4^4(4!)*14^4))(1.4) - 7((5*9*13*17)/(4^5(5!)*14^5))(1.4)
= 6.83242
So,
6.832
However, that is still being picked up as being wrong... For some odd reason. I know that the series is correct as it's already showing as correct.
NastyAccident
NastyAccident - you're almost there! However, you're not computing the power term correctly. The full term (1.4/14) should be the power term.
Let's review. You've expanded the denominator correctly - Let's put it into a more general form. The expansion of the denominator has the following form:
<br /> g(1+\xi) = g(1) + \sum_{k=1}^{\infty} \beta_k \, \xi^k<br />
where
<br /> \beta_k = (-1)^k \, \frac{\Pi_{m=1}^{k} (4m-3)}{4^k \cdot k!}<br />
and
<br /> \xi = x /14<br />
Of course, the full function approximation to f(x) would be f(x) = 7 * g(1+\xi).
Now, if we compute the first few coefficients:
<br /> \beta_1 = -1/4 = -0.25<br />
<br /> \beta_2 = \beta_1 \cdot (-5/4) \cdot (1/2) = 5/32 = 0.15625<br />
<br /> \beta_3 = \beta_2 \cdot (-9/4) \cdot (1/3) = -45/384 = -0.1171875<br />
Now, for the desired approximatiopn, you've also correctly realized that, here, the value of \xi=1.4/14 = 0.100.
It is here that lanedance was trying to give you a hint to look at the value of the various terms, considering the powers of \xi and coefficients, to determine the numbers of terms that we might need for 3 digit accuracy. Since \xi=0.1, each succesive power will decrease the significance of the term by approximately one decade.
For example, consider the magnitude of \beta_2 \xi^2 term: the contribution to the overall sum for f(x) from this term will be approximately
<br /> |7 \cdot \beta_2 * \xi^2 |= 7 \cdot |\beta_2| \cdot (0.1)^2 = 7 \cdot (1.56 \, \cdot 10^{-1}) \cdot 10^{-2} = 7 \cdot (1.56 \, \cdot 10^{-3}) = 1.09 \, \cdot 10^{-2}<br />.​
(Note the multiplication by 7). Thus we see that terms beyond this need to be taken into account. What about the next term?
<br /> |7 \cdot \beta_3* \xi^3|= 7 \cdot |\beta_3| \cdot (0.1)^3= 7 \cdot (1.17 \, \cdot 10^{-1}) \cdot 10^{-3} = 7 \cdot (1.17 \, \cdot 10^{-4}) = 8.20 \, \cdot 10^{-4}<br />.​
We see that the k=3 term will be less than 0.001 (least significant digit for three place accuracy) and will not effect the third decimal place on truncation (it will, however, effect the result upon rounding).
This is sufficient for the result to be correct to three decimal places. If we wanted to be assured that the rounded result would be accurate to three decimal places, than we would have more work to do (see below).
Hence, to be correct to three decimal places, two terms (k =1, 2) plus the "zero" term (g(1)) is needed in the expansion
Computing this requires the following:
<br /> y = 7 \cdot (1+\beta_1 \cdot \xi + \beta_2 \cdot \xi^2 )<br />
which yields
<br /> y = 7 \cdot (1 - \frac{1}{4} \xi + \frac{5}{32} \xi^2)<br /> = 7 \cdot (1 - 0.25 \cdot 10^{-1} + 0.15625 \cdot 10^{-2})<br />
which computes as
<br /> y = 7 \cdot (0.976563)<br />
<br /> y = 6.835938<br />
The actual computed value is
<br /> \frac{7}{\sqrt[4]{1.1}} = 7 \cdot (0.976454) = 6.835179<br />
Notice that the approximation is correct to three decimal places, however, the rounded approximation to three decimals places would be in error in the last digit.
As an aside, consider the rounded to three decimal places condition (not part of OP problem).
From prior analysis with three \beta terms, we would expect (hope!) that further terms are not needed since \xi will influence the next term by a factor of ten, but what about the coefficient? A quick calculation shows that the next coefficient is \beta_4 = \beta_3 \cdot (-13/4)*(1/4) and its magnitude is less than \beta_3.
Hence, a total of three terms (k = 1,2,3) plus the "zero" term (g(1) = 1) should be used in the expansion for proper approximation to three digits.
<br /> y = 7 \cdot (1+\beta_1 \cdot \xi + \beta_2 \cdot \xi^2 + \beta_3 \cdot \xi^3)<br />
which yields
<br /> y = 7 \cdot (1 - \frac{1}{4} \xi + \frac{5}{32} \xi^2 - \frac{45}{384} \xi^3)<br /> = 7 \cdot (1 - 0.25 \cdot 10^{-1} + 0.15625 \cdot 10^{-2} - 0.1171875 \cdot 10^{-3})<br />
which computes as
<br /> y = 7 \cdot (0.976445)<br />
<br /> y = 6.835117<br />
The above approximation is now accurate to three decimal places.
where
and
which yields
which computes as
which yields
which computes as
I, literally, just realized that I wasn't using the nth power of x, but was just using x. Such a silly and idiotic error on my part through off the calculation big time.
The new calculation:
7-(1/8)(1.4) + 7(5/(4^2(2!)*14^2))(1.4)^2 - 7((5*9)/(4^3(3!)*14^3))(1.4)^3 + 7((5*9*13)/(4^4(4!)*14^4))(1.4)^4 - 7((5*9*13*17)/(4^5(5!)*14^5))(1.4)^5 = 6.83518
Thank you folks! I truly do appreciate it!
NastyAccident.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
