Using Bernoulli's Equation to find pressure in a wind tunnel
The discussion revolves around a wind tunnel problem where the objective is to determine the pressure in the test section given specific conditions, including air velocity and atmospheric pressure. The subject area involves fluid dynamics, specifically the application of Bernoulli's equation.
  • Participants discuss the application of Bernoulli's equation, with attempts to isolate variables and calculate pressure. There are questions regarding the validity of pressure readings, particularly concerning gauge versus absolute pressure. Some participants express confusion about the atmospheric pressure values provided in the problem statement.
The discussion is ongoing, with participants exploring different interpretations of the pressure values and the implications of using gauge versus absolute pressure. There is no explicit consensus on the atmospheric pressure conditions, and some participants are questioning the assumptions made in the problem setup.
Participants note that the atmospheric pressure given in the problem (90 kPa) is lower than the standard atmospheric pressure at sea level (101.325 kPa), raising questions about the conditions under which the problem is set. Additionally, there is mention of a lack of prior discussion on gauge versus absolute pressure in the participants' coursework.
Tanner Ross
A wind tunnel is designed to draw in air from the atmosphere and produce a velocity of 100m/s in the test section. THe fan is located downstream of the test section. What pressure is to be expected in the test section if the atmospheric temperature and pressure are -20C, 90kPa?
Bernoulli's Equation: P1 + 1/2pv2 + pgh1 = P2 + 1/2pv2 + pgh2
p = P/RT
I canceled out the heights as it doesn't state a height difference and says the fan is downstream, so assumed its a two dimensional problem. Leaving me with:
P1 + 1/2pv2 = P2 + 1/2pv2
Then I used p = P/RT to find the density of air, which came out to be 1.24kg/m3
Then Isolated P2 = P1 - 1/2pv2, using atmospheric pressure for P1, I solved for the pressure afterwards but it came out to be -560kPa.
Now i know taking the absolute value is acceptable with pressures but this number still seems wrong to me.
err, I just tried it again and I must have punched something wrong in my calculator when I squared 100m/s.
Got a value of P2 = 83.8kPa
Atmospheric pressure is 101.325 kPa. A perfect vacuum is 0 kPa. A pressure of -560 kPa is meaningless.
No, it's not. You also need to establish if your pressure readings are gage or absolute.
Err, we have never discussed gage or absolute pressure in my fluid dynamics class thus far. It is asking what the pressure is as it blows in the wind back into the tunnel from the outside.
Tanner Ross said:
The question was regarding a vacuum suction hose, like a vacuum cleaner. Sorry, didn't specify that part, just typed out the question word for word but didn't realize it didn't mention how the vacuum was being defined as it was defined in the picture.
A perfect vacuum is still 0 kPa absolute or -101.325 kPa gage. These are two bits of data which come in handy when working with fluid flow. :)
The problem statement says that the atmospheric pressure is 90 kPa. That doesn't sound like gauge pressure.
Chet
Sigh, atmospheric pressure at sea level on Earth is generally recognized to be 101.325 kPa at a temperature of 20°C.
An atmospheric pressure of 90 kPa may be present in the problem's test section, which is also at a temperature of -20°C (Brrr! oo)), but this pressure is rather low to be an ambient condition, unless there is a hurricane or other cyclonic storm present... :rolleyes:
Yes. That was also my impression. But, that's what they gave.
  • · Replies 16 ·
