Using entry level physics to calculate minimum velocity required.
The discussion revolves around calculating the minimum velocity required for a person to jump over a pit in a car, starting from the take-off point on a ramp. The ramp angle is given as 25°, with a horizontal distance of 15m to clear and a vertical height difference of 1m. Participants discuss using projectile motion equations to derive the necessary velocity, emphasizing the importance of correctly identifying the launch angle and time of flight. There is some confusion regarding the calculations, particularly in relating time and velocity, but ultimately, one participant arrives at a solution of approximately 14.9 m/s for the required initial velocity. The conversation highlights the application of physics principles in solving real-world problems.
QuickSkope
A person is trying to jump over the pit in a car. I need to find what is the minimum speed required to make it over. This speed is calculated not from the start of the ramp, but from the take off.
Drawing of all the elements
Please excuse my ugly drawing :P.
Projectile motion equations (Where Time is a constant)
d=vot+1/2at^2
So, I am trying to find the minimum velocity required to make this jump. We know the θ of the Ram is 25°. We also know that the left side is 15m, and the right is 16m. From there, we can judge that the Ramp is more like this.
Illustration of my triangle
We know the right side is 1m higher than the left, so we have to account for that in making our triangle.
We can calculate our 2nd θ using Tan = 1/15. This yields a theta of 3.8°.
To calculate the velocity required, i used projectile motion (using time as the only constant)
Vx | Vy
d= 15m Vf= X
V=? Vo=0
T= ? <--------> T=?
d=1m
a=-9.8m/s^2Calculate T using d=VoT+1/2at^2
1= 0 + 1/2(9.8)t^2
1=4.9t^2
t=0.45s
Calculate how fast the person needs to go to make the jump
D=V * T
15 = 0.45V
V= 33 m/sDoes that make sense? I feel like I did something wrong as I did not use the 25°.
Any help is much appreciated, and if you need more info/clarification, I will obliged.
My approach to solving this problem would be to say that we want to solve for the initial speed, v0. In projectile motion, since there is no horizontal acceleration, the velocity in the x direction is constant:
vx = v0cosθ = const.
Now, for motion at a constant speed, it's just true that distance = speed*time. So the horizontal range Δx of the projectile is just:
Δx = vxt = (v0cosθ)t
You know that Δx must be 15 m to span the gap, so you can solve for t in terms of v0 and θ. That's one unknown eliminated (the time spent in the air).
Now you switch to the equations of motion for the vertical (y) direction. We have position vs. time given by:
y = y0 + v0yt - (1/2)gt2
= (v0sinθ)t - (1/2)gt2
For convenience, choose the initial vertical position (the top of the ramp) y0 to be 0 m. (It may be 15 m above your ground level, but why not measure heights from the top of the ramp?) So, that makes your final vertical position y = 1 m. So you can find the t that satisfies this equation for y = 1 m, and set that equal to the t from before.
How would I solve X=Vxt? I only know X=15, which leaves 2 variables.
I believe I did it backwards from you, finding the time required in the Y, and
using it in my Vx. Does that make my answer false?
Also, can the Theta not be found using just Tan=1/15?.
Read my post more closely. vx = v0cosθ, so this equation allows you to solve for t in terms of v0, which is the thing you're trying to solve for, and θ, which is given, NOT unknown (see below)
The order in which you use the equations doesn't matter. The y equation will give you the time required to reach a height of 1 m at a given launch speed, and then you can plug that into your x equation to solve for the launch speed that gives you the right horizontal range.
That's the wrong theta. You want the launch angle of the projectile, which is the ramp angle, which is already given to be 25°. So, as I said above, θ is already known.
So, solving for T in terms of Vo would give you:
t= 15/VoCos25
Correct?
And then I am lost from there, because you can't solve the next equation (y = y0 + v0yt - (1/2)gt2) for t. If I could solve for t=, then I could just put the 2 equations together and solve for Vo, Correct?
Sorry, I'm a little confused and not quite grasping it.
Thanks so much.
bump?
Ive tried subbing in the first equation (t=15/VoCos25) into the 2nd equation, but ended up with Vo^3 and it was just a mess. I am quite lost on this question still.
Thanks in advance.
t= 15/VoCos25
Correct?
Thanks so much.
Why not? It's a quadratic. Have you heard of the quadratic formula?
Never mind, I forgot to cancel out a V, ended up with 14.9m/s for my Vo, and I believe it works :).
Thanks for the help :D
  • · Replies 38 ·
