Using Hooke's Law and Elastic Potential Energy equations
This discussion clarifies the application of Hooke's Law (F = kx) and the equation for elastic potential energy (W = 0.5kx²). The user initially confused the use of these equations for calculating the spring constant (k). The correct approach is to use F = kx for constant force scenarios, while W = 0.5kx² applies to variable forces, specifically for springs where the force changes linearly with displacement. The key takeaway is that the work done by a spring is based on the average force, not the instantaneous force.
  • Understanding of Hooke's Law and its formula (F = kx)
  • Knowledge of elastic potential energy and its formula (W = 0.5kx²)
  • Concept of variable versus constant forces in physics
  • Basic calculus for understanding work done by variable forces
  • Study the derivation of the work done by a spring using calculus
  • Explore the concept of average force in variable force scenarios
  • Learn about the applications of Hooke's Law in real-world systems
  • Investigate the differences between conservative and non-conservative forces
Students studying physics, educators teaching mechanics, and anyone interested in understanding the principles of elasticity and energy in spring systems.
mp9191
I'm just having a bit of trouble understanding when to use F=kx and when to use W=.5kx^2 .
I understand that Hooke's law is for the spring force and elastic PE is obviously for work, but you could use either one of these equations to solve for, for example, k:
When solving for the spring constant k, you could use F=kx:
k = F/x
or, using elastic PE and the fact that W=F(cos0)x,
.5kx^2 = F(cos0)x
k= 2F/x
There is a flaw in my thinking somewhere but I'm just not seeing it. Could someone please help clarify this for me?
Thanks in advance!
k = F/x
.5kx^2 = F(cos0)x
k= 2F/x
Thanks in advance!
That is a keen observation you have made, even though the 2nd result is incorrect. It shows nonetheless that you are putting forth a good effort to understand the principles. The reason why the 2nd result is wrong is because you assumed the spring force was constant. The equatioin W =Fxcos theta is valid for constant force. The spring force kx is not constant, it varies linearly as a function of x. So the work done is the average force of the spring times the distance. What is the average force of the spring as it moves from 0 to x? Or, if you like, you can use the calculus to solve for the work, W = _____?
Ah, I see. I was overlooking the fact that W=Fxcos theta is only valid for constant forces. Your explanation was very clear. Thank you for the help!
  • · Replies 21 ·
