Using iff notation between equation lines in a proof
  • Thread starter Thread starter halvizo1031
    Solving equations
25 replies · 5K views
halvizo1031
I am having trouble with question 4(c)... part i and ii...
would it be okay for her to write iff between each line? I do not see why not but I cannot find the proper reasoning.
Well, you're correct. In her attempt in part (i), it is ok to write iff in every line. Can you argue for each line why it is allowed?
the only reason i can think of is that she's not really changing the orginal equation. she is only simplying it.
Yes! If I were your instructor, that would certainly be a good answer. But I don't really know what they want to hear. You could also mention the laws involved: for example, you could say that in the first line, she used distributivity, etc.
Anyway, what do you think of the second part?
well my thinking for part ii is that since (x-3) is always smaller than (x), then we would have a small number minus a big number which would give us a negative solution...thus, since the equation is equalled to 5, there must be no solution.
Yes, but it would be nice to elaborate a bit.
For example, [tex]x-3\leq x[/tex], implies that [tex]\sqrt{x-3}\leq \sqrt{x}[/tex]. thus [tex]\sqrt{x-3}-\sqrt{x}\leq 0[/tex], which implies that the left-hand side can never equal 5.
i see...then, may I use the same reasoning for part (d)?
Can you explain your reasoning?? As the question states, you will not be able to use the exact same reasoning here!
i need some time to think about the reasoning here...i'm not quite sure i see it.
thus, sqrt of 1-x will always give us a complex answer?
Not necessarily, since x could be 0 for example, then [tex]\sqrt{1-x}=1[/tex]. But I like your way of thinking...
i'm not quite sure what it is the question is looking for ...
it seems to me that stating that the equation will give a complex answer when x>1
Yes, when x>1, then sqrt(1-x) is not a real number. Now, what about your other term, sqrt(x-1)? What is that when x<1?
if x < 1 then i will also get a complex solution here...therefore, i will always have a complex solution to the equation for any value of x except 0?
My only concern is that in the third line she uses:
[tex] \sqrt{a^{2}}=a[/tex]
and not:
[tex] \sqrt{a^{2}}=\pm a[/tex]
But he simply does [tex]\sqrt{4}=2[/tex], which is certainly correct? The square root is always a positive number...
Perhaps, but I was a little unsure about that. I don't know what the conventions they're using.
The usual convention in mathematics is that this sign: [tex]\sqrt{}[/tex] is used to define the positive square root of a number.
the way i see it is that for any value i plug in for x (except 1), the left hand side will always give me a complex answer which does not equal 1.
Yes, so the only possible solution is 1, which can be easily checked.
hold on, if i plug in 1 for x, wouldn't i get 0 = 1?
halvizo1031 said:
hold on, if i plus in 1 for x, wouldn't i get 0 = 1?
And because that's not true, you've proven that it cannot be true for x<1, x>1, or x=1. Congrats!
