Using instantaneous torque to determine energy
This discussion focuses on calculating energy consumption in kilowatt-hours (kWh) using instantaneous torque measurements from electric motors. Key formulas include Power = Torque * Angular Velocity, where Power is in Watts, Torque in N-m, and Angular Velocity in Rad/s. To convert RPM to Rad/s, multiply by 2π/60, and to convert Watts to kWh, use the formula (60*60)/1000. It is crucial to measure both torque and angular velocity to accurately determine mechanical energy output, while also considering motor efficiency for energy consumption calculations.
  • Understanding of Torque and Angular Velocity
  • Familiarity with Power calculations in physics
  • Knowledge of unit conversions (RPM to Rad/s, W to kWh)
  • Basic principles of motor efficiency
  • Learn how to integrate torque measurements over time for energy calculations
  • Research methods for measuring electrical energy consumption directly
  • Study the impact of motor efficiency on energy consumption
  • Explore advanced torque and power measurement techniques in electric motors
Engineers, electrical technicians, and researchers involved in motor performance analysis and energy consumption optimization will benefit from this discussion.
JohnMC2010
Hi all - This may seem like a very simple exercise, but for some reason it's giving me trouble...
I am trying to determine the difference in energy (ultimately looking for kWh) used between two different electric motors by utilizing instantaneous torque measurements I have. I would like to do this so that I can chart energy consumption instantaneously as well across different motor speeds. Here's what my thought process is:
- Integrate torque signal in N-m: This gives me N-m-sec so that I have cumulative torque over a fixed duration (sec)
- But a Watt = 1 Joule/sec...?
Again... Silly question, but somehow I'm stumped
Boy, I'll say you're stumped. But posting your question in Astronomy and Astrophysics is unlikely to attract many helpful responses.
Power = Torque * angular velocity.
where
Power is in Watts
Torque is in Nm
To convert rpm to Rad/s multiply the rpm by 2Pi/60.
To convert W to kWh just multiply by (60*60)/1000.
PS: You need both the torque and rpm/angular velocity. You can't do it with just the torque.
Google foot pounds per second to watts, and you get 1.35581795 watt.
You stated you were trying to "chart energy consumption instantaneously", but measuring the torque and angular velocity of the motor output won't give you that. It will give you mechanical energy output which will only be a lower bound on energy consumption. Consumption and output will always differ by the efficiency of the motor, which could vary widely depending on speed and load.
Why not measure the electrical energy directly?
CWatters answered in his PS, maybe it could use some emphasis ?
Torque has the units force X distance but is not work.
You can prove that to yourself - put a wrench on a tight nut and push gently. No movement = no work done. Work has units force X distance moved
that's why you must multiply torque by angular displacement to get work
i'm old,
in the English units of my day
horsepower = 2 X π X Torque(in foot-pounds_RPM /33,000
integrate product of torque and ω
∫ nm X radians/sec = nm = joules ,,, since radians are unit-less
any help ?
  • · Replies 74 ·
9K
  • · Replies 16 ·
12K
