Using Kinematics equasions to solve
  • Thread starter Thread starter Mathewpaasch
    Kinematics
Kelsi and Sara are conducting an experiment to determine the height of a building using kinematics. Kelsi measures the height of a window at 4.0 feet and times a super ball dropped from the building as it passes the window. The ball takes 0.125 seconds to fall past the window and a total of 1.125 seconds to hit the sidewalk and bounce back to the window. The discussion focuses on identifying the necessary kinematic equations to calculate the building's height, considering the time intervals measured. The participants express uncertainty about how to begin the calculations.
Mathewpaasch
Kelsi and Sara are going to determine the height of tall building. Kelsi went to third floor hallway and measured the height of the window there to be 4.0 ft. Sara will drop a supper ball from the top of the building such that it will pass by the window. Kelsi starts a chronometer when she sees the ball at top of the window, reads the time as the ball passes the bottom of window. She reads 0.125s for this event, and does not stop the timer. The timer continues to run while the ball hits the side walk, bounces back and passes by the window again. Kelsi stops the chronometer as soon as she sees the ball arriving at bottom of the window. The timer reads 1.125 seconds.
Neglecting the air resistance, what do they calculate for the building height?
not sure where to start
What are the equations you think you will need?
  • · Replies 36 ·
  • · Replies 16 ·
