Using Remainder Theorem to find remainder
6 replies · 2K views
Schaus
(y4 - 5y2 + 2y - 15) / (3y - √(2))
The answer says (2√(2)/3)-(1301/81)
https://lh3.googleusercontent.com/tdxTK9jIztkS5_7q9x0jP_D3HdkcDcKO9K_T2glYcdlF5MW71SiVq0xNjj09bkX3yUTi0lVS5aehQcTCpjVMgEyIEySNwanKwnxkfuh-l9wGnecvNy11IkibZd5nNgn4eiv4l3I-SGY89O9V_M2uzlcRBLfMVMkS_gybhaz3be3-eDmspF47-z1thzMs6iseX2eU2IjJMpAmx0YjN4mrOY4Bx7hQtrUnyMA4GSXyavCjbLx89CaKmAU6bbqm36Qqm3ieAW1299QOvcXrBqH2XaT_u9T_THz1ktwI9a_Mw5ozQurH0RnZvOIWbArej-6PU9mOWIpvasISRaLkwCWpG_w76wjFjZGISRXhq33LvWxM4bGFbvirN6c--KFp5yLWC7djePdwbpb69UF5FbPYJxOuBIWoaVg1QPwwg0V7im1Zp0fThljuNWHmwyM1vA6tXhnc5zkx7WnZ8BCiP2feBXWOdal8yvnTA0BXY8O0_Ly1YSO8fqX1mATZ8RY8YlawtMB_FMwuNsAYVJ6Vde0tdPFQEYlQ3yYERXpeo-31kNJRs_Y9wP5pWUp58FTVgyBsOmwiztqNVUVJyQfnMiKjDKJeR9_wevbfnEStla1ntJRTakXqP8dG=w449-h311-no
Using synthetic division
3y - √(2) = 0
3y = √(2)
y = √(2)/3
My final answer that I keep getting is (2√(2)/3)-21. I can't seem to get (2√(2)/3)-(1301/81). I was just wondering if someone could show me where I'm going wrong? Sorry writing this out was very difficult so I hope you can still understand it.
I don't actually can follow your calculations. If I compare my calculation with your result, then I think you simply lost some denominators.
I get ##\frac{4}{81}-\frac{10}{9}-15+\frac{2\sqrt{2}}{3}## whereas you seem to have added only the nominators ##4-10-15+\frac{2\sqrt{2}}{3}##.
I once gave an example on PF here:
https://www.physicsforums.com/threa...r-a-polynomial-over-z-z3.889140/#post-5595083
Maybe it helps.
Sorry, I should have just posted this to begin with.
Schaus said:
View attachment 111547 Sorry, I should have just posted this to begin with.
Your long-division process is all wrong. Let ##p(y) = y^4 - 5y^2 + 2y - 15## and ##d(y) = 3y - \sqrt{2}##. You want to find a "quotient" ##q(y)## and a number ##r## (the "remainder") that give you ##p(y) = q(y) d(y) + r.## The question is asking you to find ##r##.
Step 1: see how many times the leading term of ##d(y)## will go into the leading term of ##p(y)##; that is the number of times ##3y## goes into ##y^4##. The answer in this case is ##y^4/(3y) = (1/3)y^3##, so that is the first term in your quotient ##q(y)##. Now we have
$$ p(y) - \frac{1}{3} y^3 d(y) = \frac{\sqrt{2}}{3} y^3 -5 y^2 + 2y - 15 \equiv p_1(y).$$
However, all that would be doing it the hard way. The easy way would be to go ahead and use the "remainder theorem".
Step 2: see how many times the leading term of ##d(y)## goes into the leading term of ##p_1(y)##. The answer is ##(\sqrt{2}/3)/(3 y) = (\sqrt{2}/9) y^2##, so that is the next term in your quotient ##q(y)##. We have
$$p_2(y) \equiv p_1(y) - \frac{\sqrt{2}}{9} y^2 d(y) = -\frac{43}{9} y^2 + 2y - 15.$$
So, up to now we have
$$p(y) = \left( \frac{1}{3} y^3 + \frac{\sqrt{2}}{9} y^2 \right) d(y) + p_2(y).$$
Keep going like that; the next term in the quotient ##q(y)## will be the number of times the leading term of ##d(y)## goes into the leading term of ##p_2(y)##, so is the number of times ##3y## goes into ##-(43/9) y^2##, etc., etc.
The remainder will be what you have left when the process comes to an end.
However, all that would be doing it the hard way; I included the material just because you attempted to do it, but did it all wrong. The easy way would be to just use the so-called "remainder theorem".
I was using synthetic division which worked on every other question but I'll try it the way you're suggesting it.
I got the same result as the answer. Thanks for your help!
It looks to me like you simply made a couple multiplication errors when working with fractions. I worked the problem with synthetic division and got the right answer.
