Vacuum vs. Compression: Which Requires More Energy?
  • Thread starter Thread starter violin_writer
    Compression Vacuum
The discussion centers on the energy requirements for decompressing air to a vacuum versus compressing air, exploring the conditions and scenarios under which each process occurs. Participants examine the implications of different pressures and the mechanics involved in both processes.
  • Some participants question the clarity of the original question regarding decompressing air to a vacuum and suggest that more specific parameters are needed.
  • One participant argues that pulling a vacuum is generally tougher due to the propensity for leaks in vacuum systems.
  • Another participant presents a scenario involving a piston/cylinder arrangement, calculating the energy required to pull or push the piston in both vacuum and compression modes, highlighting the differences in energy requirements.
  • There is a mention of the infinite energy requirement when attempting to achieve a perfect vacuum, indicating that practical limits must be considered.
  • One participant shares an experience with vacuum pumps, noting that the current drawn to maintain a hard vacuum is low compared to that of an industrial compressor, but emphasizes the need for absolute definitions in the discussion.
Participants do not reach a consensus, as there are competing views on the energy requirements for both processes and the specifics of the scenarios being discussed. The conversation remains unresolved with multiple interpretations of the original question.
Limitations include the lack of specific parameters for the scenarios discussed, the dependence on definitions of "absolute vacuum" and "absolute compression," and the unresolved nature of the energy calculations presented.
violin_writer
I wander...
which would require more energy, to decompress air like a vacuum or compress air?
How would you be able to decompress air to an absolute vacuum? And compress air up to what pressure?
"decompress air like a vacuum"
is a meaningless statement.
Yes, you'll need to be much more specific about what you are talking about. Do you have a specific scenario in mind?
Im assuming its a similar thing to pumping losses in an engine.]
i.e is it harder to compress air trapped in a cylinder, or to pull against a vacuum.
That's the way I read it. In reality, it is tougher to pull a vacuum because those systems are much more prone to leaking.
FredGarvin said:
That's the way I read it...
See, the problem here is that I read the same thing that Chris said and reach exactly the opposite conclusion! We need more info about what the OP is getting at. Anyway...
I wasn't thinking the OP really meant energy because in either case, energy could be infinite depending on what you are asking. Ie, since you can't generate a perfect vacuum, you would expend an infinite amount of energy in the attempt. At the same time, compressing air requires more and more energy as well and the OP didn't specify parameters. Here's what I thought of when I read the OP:
Consider a piston/cylinder arrangement, such as a syringe, 1/2" cross sectional area, 4" long. The syringe is half full of air at atmospheric pressure and is closed. How much energy is required to pull or push the piston 1" in either direction? Roughly:
Pulling on the syringe and moving it 1" would yield a minimum internal pressure of 7.4 psi, force of 3.7 lb, and work of 1.8 inch-pounds. In fact, the maximum possible force you could generate with such a syringe in "vacuum pump mode" is 7.4 lb, which limits the amount of work requried to move the piston. Not so in "compressor mode":
Working as a compressor, pushing it 1" yields a pressure of 14.7 psi, a force of 7.4 lb, and requires a work of 3.7 in-lb.
hi i know what you mean, whilst i was with edwards vcauum when we used to un the vacuum pump and test the current drawn ,,oncea hard vacuum is reached say.005 mbar vacuum the level of current amps to hold this pressure is qyuite low in compairiosn to an industrial compressor..but its not really relative unless you wre talking absolute compression and absolute vacuum as there are way too many variables
  • · Replies 22 ·
  • · Replies 56 ·
  • · Replies 16 ·
