Validity of identical eigenfunction of commutating operators
  • Context: Undergrad
  • Thread starter Thread starter hokhani
The discussion revolves around the validity of the statement that two commuting operators, specifically ##\hat {\mathbf L_z}## and ##\hat {\mathbf L^2}##, always have identical eigenfunctions in quantum mechanics. Participants explore the implications of this statement, particularly in the context of eigenfunctions and eigenvalues, and whether certain functions can be eigenfunctions of one operator but not the other.
  • One participant expresses confusion about the statement that commuting operators have identical eigenfunctions, noting that a function of the form ##\psi=f(r,\theta) e^{im\phi}## is an eigenfunction of ##\hat {\mathbf L_z}## but not necessarily of ##\hat {\mathbf L^2}##.
  • Another participant clarifies that while commuting operators share some eigenfunctions, not all eigenfunctions of one operator are eigenfunctions of the other.
  • It is mentioned that there can be degeneracy in eigenvalues, leading to multiple eigenvectors corresponding to the same eigenvalue, which complicates the relationship between the eigenfunctions of the two operators.
  • Participants discuss the implications of using a nondegenerate basis and the diagonalization of operators, suggesting that superpositions of eigenstates may still be eigenfunctions of one operator but not the other.
  • One participant points out that the original function proposed in the discussion is a superposition, which may not satisfy the eigenfunction condition for both operators.
  • Clarifications are made regarding the nature of Hermitian operators and the identity operator in the context of eigenvalues and eigenvectors.
Participants do not reach a consensus on the original statement regarding identical eigenfunctions of commuting operators. There are multiple competing views, particularly concerning the nature of eigenfunctions and the implications of degeneracy.
The discussion highlights limitations in understanding the relationship between eigenfunctions of commuting operators, particularly in cases of degeneracy and superposition. The implications of using specific bases for analysis are also noted.
This discussion may be of interest to students and professionals in quantum mechanics, particularly those exploring the properties of operators and eigenfunctions in the context of quantum systems.
hokhani
TL;DR
An example of a function which is eigenstate of ##\hat {\mathbf L_z}## but not ##\hat {\mathbf L^2}##
I got confused about an elementary statement in quantum mechanics: As far as I know, the two commuting operators like ##\hat {\mathbf L_z}## and ##\hat {\mathbf L^2}## always have identical eigenfunctions. But, if we consider every function in the form ##\psi=f(r,\theta) e^{im\phi}## where ##f(r,\theta)## is any function including the normalization coefficient, then, this function is always eigenfunction of ##\hat {\mathbf L_z}## (##\hat {\mathbf L_z} \psi=m\hbar \psi## ) but it is not always the eigenfunction of ##\hat {\mathbf L^2}##. What’s wrong with my thinking here?
If two operators commute, then at least some of the eigenfunctions of one will be eigenfunctions of the other - but not necessarily all. It kind of has to be that way; otherwise any eigenfunction of ##L^2## would be an eigenfunction of both ##L_x## and ##L_y## because both commute with ##L_2##.
Consider$$A=\begin{pmatrix}1&0\\0&2\end{pmatrix}$$and the identity ##2\times2## matrix ##I##. Surely$$v=\begin{pmatrix}1\\1\end{pmatrix}$$is an eigenvector of ##I##.
Thanks, but by operators I meant Hermitian operators.
All Hermitian operators commute with ##I##. And every vector is an eigenvector of ##I##.
This is wrong. There must be a common eigenbasis. But, one operator might have two (or more) eigenvectors corresponding to the same eigenvalue. This is called degeneracy. In this case, the operator will have a mutli-dimensional eigenspace corresponding to that eigenvalue Whereas, if the other operator does not have this degeneracy, then it has two separate one-dimensional eigenspaces, corresponding to the different eigenvalues.
So which one is not Hermitian in my example, ##I## or ##A## ?
Edit: for 2 commuting observables there is a basis in which they are both diagonal. Instead of looking at the infinite-dimensional representation, it is easier to consider a ##2\times2## restriction that demonstrates the same basic idea.
Thanks, but let's write the commutation in the nondegenerate basis of ##\hat {\mathbf L_z}##, i.e., ##|m\rangle##. We have: $$\langle m| [\hat {\mathbf L_z}, \hat {\mathbf L^2}]|m' \rangle =0 \rightarrow (m'-m)\hbar \langle m| \hat {\mathbf L^2}|m' \rangle=0.$$ which means that ##\hat {\mathbf L^2}## is diagonal in the basis##|m\rangle##. What is wrong with this statement?
Nothing. All eigenvectors of ##L_z## are eigenvectors of ##L^2##. But there are eigenvectors of ##L^2## that are not eigenvectors of ##L_z##.
Sorry, you are right.
However, in the post #1, I sent the function ##\psi=f(r,\theta) e^{im\phi}## which is always the eigenfunction of ##\hat{\mathbf{L_z}}## but not always the eigenfunction of ##\hat{\mathbf{L^2}}##.
Hints don't seem to work, so I'll say it explicitly: superpositions of the common diagonalizing basis vectors may still be eigenfunctions of one observable, but not necessarily of the other.
Could you please see the post #7? It approves more the discrepancy said in the post #1.
As @PeroK replied in #8, nothing is wrong with #7. Only basis states are considered there. But your ##\psi## in OP (#1) is a superposition in general.
Edit: the error in #7 is claiming that ##\mathbf{\hat L}_z ## is nondegenerate. There are infinitely many states in the ##|l,m\rangle## basis for which ##m=1## .
##|1,1\rangle## and ##|2,1\rangle## are eigenstates of both operators. However, ##|1,1\rangle+|2,1\rangle## is an eigenstate of ##\mathbf{\hat L}_z ## but not of ##\mathbf{\hat L}^2 ## (if you'll think about it, it is my example in #3).
  • · Replies 56 ·
  • · Replies 27 ·
  • · Replies 0 ·
  • · Replies 16 ·
