Is the Rewriting of Logs Valid for All Values of x?
  • Context: Undergrad
  • Thread starter Thread starter CAF123
    Laws
The discussion centers on the validity of rewriting the logarithmic expression ##\ln(1-1/(1-x))## in terms of ##\ln(1-1/x)## for values of ##x## in the interval (0,1). It is established that the manipulation fails at ##x = 1/2## due to the logarithm of a negative number, which is undefined in the real number system. The correct approach involves analytic continuation, leading to the expression ##\ln(1-1/(1-x)) = 2i\pi - \ln(1-1/x)##, which holds for ##x## in (0,1) except at ##x = 1/2##.
  • Understanding of logarithmic properties and identities, specifically the laws of logarithms.
  • Familiarity with analytic continuation in complex analysis.
  • Knowledge of the domain restrictions of logarithmic functions.
  • Basic comprehension of complex numbers and their properties.
  • Study the properties of logarithmic functions in complex analysis, focusing on multi-valued aspects.
  • Learn about analytic continuation and its applications in complex functions.
  • Explore the implications of domain restrictions on logarithmic expressions.
  • Investigate the behavior of logarithmic functions at critical points, such as ##x = 1/2##.
Mathematicians, students of complex analysis, and anyone interested in advanced logarithmic manipulations and analytic continuation techniques.
CAF123
Perhaps this is a simple question but I can't see a way to understand it. I have some expression of the form ##\ln(1-1/(1-x))## and I perform the following manipulations using simple algebra and laws of logs:
$$\ln \left(1-\frac{1}{1-x}\right) = \ln \left(\frac{1-x-1}{1-x}\right) = \ln \left(\frac{x}{(x-1)}\right) = -\ln \left(\frac{x-1}{x}\right) = -\ln \left(1-\frac{1}{x}\right)$$
I am doing such manipulations under the premise of ##x \in (0,1)##. However, if I put x equal to 1/2 then the left hand side does not match the right hand side. It does for x otherwise though. So, is it correct that the above rewriting is only valid for x not 1/2 and ,if so, why and how to rewrite ##\ln(1-1/(1-x))## in terms of ##\ln(1-1/x)## valid for ##x \in (0,1)##?
If we're dealing with the real number system, when ##x = 1/2## then ##\ln \left(1-\frac{1}{1-x}\right) ## doesn't exist because -1 isn't in the domain of ##ln()##.
I think at the end of the day I want to analytically continue the x. The law of logs ##b\ln(a) = \ln(a^b)## is only valid if a is positive... I rewrote my term as follows $$\ln(1-\frac{1}{1-x}) = \ln(\frac{x}{x-1}) = \ln(\frac{-x}{x-1}) + i\pi = -\ln(\frac{1}{x}-1) + i\pi.$$ Then used ##\ln(-z) = \ln z + i\pi## again to write $$\ln(1-1/(1-x)) = 2i\pi - \ln(1-1/x)$$
Is this now a correct rewriting of log(1-1/(1-x)) given that my x is restricted to x in (0,1)?
Are you trying to find an identity that applies to (the principal value of)##ln(z)## for ##z = a + bi## where ##b## is an arbitrary real number? Or are you only trying to find an identity that works just for the case ##b = 0##?
Let's change it a little, to get rid of the problem with analytic continuation and log of negative numbers:
Assume ##x\in (0,1)##. Then:
$$\ln \left(\frac{1}{1-x}-1\right) = \ln \left(\frac{1-(1-x)}{1-x}\right) = \ln \left(\frac{x}{1-x}\right) = -\ln \left(\frac{1-x}{x}\right) = -\ln \left(\frac{1}{x}-1\right)$$
This holds also for ##x=\frac12##, because then both sides are ##0##.
Hi @Stephen Tashi,
Upon further analysis of my problem, I see that I want my x to take values in (-1,1) and not (0,1). I want to get an identity involving logs with b=0 only.
I'm given that the analytic continuation of terms of the form ##\ln(1+1/x_-)## and ##\ln(1-1/x_+)## are given by replacements ##x_+ \rightarrow x - i\theta(x)\epsilon## and ##x_- \rightarrow x + i \theta(-x)\epsilon## and taking the limit ##\epsilon \rightarrow 0^+##. I would like to consider what these terms look in each of the regions ##x>0## and ##x<0##. In the latter case, the above formulae tell me that ##x_+ = x## and ##x_- = x + i\epsilon##. So, in this region, I can simply write ##\ln(1-1/x_+) = \ln(1-1/x)##. The other term ##\ln(1+1/x_-)## is more difficult:
The analytic continuation tells me that in region x<0, ##x_- ## is at ##x+i\epsilon##, so at angle ##\pi-\epsilon## from the negative real axis. Therefore I believe I can use the formula $$\ln(-z) = \ln(e^{i\pi}z) = i\pi + \ln z$$ but what is my ##z## here?
Thanks for any comments!
As I understand "analytic continuation" it begins with an analytic function defined on a open subset of the complex plane (rather than with "terms" of some form). So what function and what open subset of the complex plane do you wish to consider?
I think all this with analytic continuation and principal values misses the point. It was unfortunate that CAF123 chose an argument of ln which was negative, and got problems because log is multi-valued. But this has little to do with the original problem with an expression u such that u = -u (for x=1/2). But this is no problem if u=0, which is easily seen to be the case if we change the original expressions a little, so that we only get ln of positive numbers, which I did my post #5 above.
Ah sorry I guess I meant to say the ##\ln( 1 \pm 1/x_{\mp})## are the functions I wish to consider. Perhaps it's worth explaining a little more what I wish to do. Basically I've done an exercise and my result (a function involving sums of logs and square of logs) is only a function of this x. I'm comparing to a result which involves this x (only in rational prefactors which we probably don't need to worry about) but also ##x_+## and ##x_-## through the logs. So I wish to rewrite this latter result entirely in terms of x so I can compare to my result. To do so, I have to use the proposed 'analytic continuations' ##x_+ \rightarrow x - i\theta(x)\epsilon## and ##x_- \rightarrow x + i\theta(-x)\epsilon##. I'm not sure if 'analytic continuation' is the correct way of saying what I wish to do but I just wish to rewrite e.g ##\ln(1 + 1/x_-)## solely in terms of x.
I try to see if the results match in a certain region of x. E.g for x<0, ##x_+ \rightarrow x## and ##x_- \rightarrow x + i\epsilon##. I can now insert this ##x_-## into ##\ln(1 + 1/x_-)## but it's how to deal with the ##i\epsilon## that's confusing me a bit.
My thinking is that these ##x_+## and ##x_-## are introduced as a compact way of writing the log to cover both regions, x>0 and x<0.
Is my intentions a little clearer? Thanks!
