Is a=g/3 the only solution or are there other possible solutions?
  • Thread starter Thread starter UchihaClan13
    laws of motion
The discussion centers on solving the differential equation xg=x*(dv/dt)+v^2, leading to the solution v=at with the constant a determined to be g/3. The participant, UchihaClan13, explores the relationship between the constants a and g, questioning whether one can be expressed as a function of the other. Insights reveal that while a can be assumed as a function of g, the ratio remains constant, confirming that k is indeed a constant even if g varies. This understanding solidifies the solution and the assumptions made during the problem-solving process.
  • Understanding of differential equations, specifically the form xg=x*(dv/dt)+v^2.
  • Familiarity with the concept of acceleration and its representation as constants.
  • Knowledge of the relationship between variables in calculus, particularly in the context of functions.
  • Basic grasp of gravitational concepts and their implications in physics.
  • Explore advanced techniques in solving differential equations, focusing on variable separation methods.
  • Study the implications of constants in physics, particularly in relation to gravitational acceleration.
  • Investigate the concept of functions of variables in calculus, including how to derive relationships between them.
  • Learn about the application of constants in physics experiments and how they affect the outcomes.
Students and professionals in physics and mathematics, particularly those dealing with differential equations and the principles of motion. This discussion is beneficial for anyone looking to deepen their understanding of the relationship between constants in physical equations.
UchihaClan13
xg=x*(dv/dt)+v^2 is a differential equation
Which has a solution of the form v=at
Where a is a constant.Find a
dv/dt=v*(dv/dx)
V=dx/dt
A=dv/dt=d^2x/dt^2
I assumed 'a' as a function of g
That is a=kg for some constant k
And proceeded
I did get the correct answer a=g/3
My question is since both a and g are accelerations and constants
Is it correct to assume one as a function of the other?
For 2 arbitrary constants a and b, we have (a=kb) for another constant 'k' where a and b are never equal to zero at the same time
I hope my approach is correct
Any confirmations and insights are much appreciated!
UchihaClan13[/B]
I can post the rest of the solution if required
All I need is some confirmation
UchihaClan13
Since they are constants, you have not really assumed one is a fixed function of the other. Rather, you have assumed that the ratio between them is also a constant, which is trivially true.
Yeah sorry
That's what I did
But y=kx (say)
Doesn't this lead to y=f (x)
For different values of x, won't we have different values of y
The only difference with this case and my original one is that
In my original one, both were constants
While in this one, both are variables
X being the independent variable and y being the dependent one
Is my reasoning correct then??UchihaClan13
UchihaClan13 said:
Yeah sorry
That's what I did
But y=kx (say)
Say we consider g to be a variable; we might run the same experiment in a different gravitational field. You say you assumed a=kg for some constant k, but you never used the assumption that it was constant. So instead, you could say let a, as function of g, be g times some other function of g, namely k(g). That would be quite valid and general.
But to solve the problem, you must assume dg/dt=0. You are given da/dt=0, so dk/dt=0. This allows you to substitute k(g)g for a and obtain k=1/3, a constant. So it turns out that k is constant even if g varies.
I see what you mean
Since the first derivative of g is zero,it implies g is a constant
And we already have da/dt=0 from the problem statement
So this would force dk/dt=0 meaning k would be a constant
Thanks a lot for your help
UchihaClan13
  • · Replies 69 ·
