Varying timing of eclipses of Algol and constant speed of light?
The discussion revolves around the timing of eclipses of Algol and the implications of the constant speed of light in relation to the Earth's motion. Participants explore how the Earth's varying distance from Algol affects the observed timing of these eclipses, considering both theoretical and empirical perspectives.
  • Some participants note that during certain times of the year, the Earth's motion towards or away from Algol affects the timing of observed minima, suggesting that this is due to the distance light has to travel.
  • Others argue that the varying timing is not solely due to motion but rather the changing distance to Algol, emphasizing that light travels at a constant speed regardless of the observer's motion.
  • A participant challenges the notion of a constant speed of light relative to all observers, using an analogy of cars approaching an observer to illustrate perceived changes in timing based on relative motion.
  • Another participant suggests that the hypothesis of varying speed of light should be tested by comparing measurements across different frames of reference.
  • Some participants express disagreement over the justification of using the concept of "aether" to explain the phenomena, arguing that it is unnecessary and not supported by the discussion.
  • A later reply discusses the implications of special relativity (SR), positing that the time required for light to travel depends on the emitter's and receiver's positions at the time of emission and reception.
  • One participant emphasizes that the speed of light is constant within an inertial frame and questions the application of this principle in the current discussion.
Participants express multiple competing views regarding the implications of the Earth's motion on the timing of eclipses and the nature of the speed of light. There is no consensus on whether the speed of light is constant relative to all observers or if it varies based on the observer's motion.
Some participants highlight limitations in the discussion, such as the reliance on a single frame of reference and the need for further testing of hypotheses regarding the speed of light.
O Great One
Take a look...
http://calgary.rasc.ca/algol_minima.htm
In May and November, the Earth is moving at "right angles" to the line to Algol. During this time we see minima happening regularly at their 2.867321 day intervals. However, during August, the Earth is rapidly moving towards Algol at about 107,229 km/hr as explained on my How Fast Are We Moving? page. (The Earth moves approximately 202 times its own size in one day.) So in 2.867321 days the Earth moves about 7,379,039 km closer to Algol. But the varying light from Algol doesn't know this - its light waves left Algol 93 years ago and are traveling at a constant speed. The result - we "catch a bunch of minima early" during August as shown on Chart 2. Exactly the opposite happens during February - the Earth is moving away from Algol that fast and it takes longer for the group of minima to reach us so we see them taking longer between events. How long? 7,379,039 km divided by the speed of light 299,792.458 km/sec is 24.61382 seconds - this rough calculation explains the deviations we see in Graph 2. So in May and November when we are not moving towards or away from Algol - the period seems constant. It is our rapid movement towards or away from the events in August and February that causes the timing differences.
Now then, if light always passes us at the same speed then what is causing the decrease in time between eclipses when we are moving towards Algol and an increase in time between eclipses when we are moving away from Algol?
It's not the moving per se, but the fact that you are closer or further away. The key bits from the link you provided are:
"So in 2.867321 days the Earth moves about 7,379,039 km closer to Algol."
"its light waves left Algol 93 years ago and are traveling at a constant speed."
"7,379,039 km divided by the speed of light 299,792.458 km/sec is 24.61382 seconds"
"this rough calculation explains the deviations we see in Graph 2"
Hmmm...Nobody is willing to admit that which is plainly obvious. Namely, that we have empirical evidence that the speed of light is not constant relative to all observers. If you have cars traveling towards you at a constant speed and they are equally spaced apart and you increase your velocity in the direction opposite to their movement (i.e. run towards them), then the time between each car is decreased and the cars' velocity relative to you is increased. So, another way of stating this is...
In May and November, the Earth is moving at "right angles" to the line to Algol. During this time we see minima happening regularly at their 2.867321 day intervals. However, during August, the Earth is rapidly moving towards Algol at about 107,229 km/hr as explained on my How Fast Are We Moving? page. (The Earth moves approximately 202 times its own size in one day.) So in 2.867321 days the Earth moves about 7,379,039 km closer to Algol. But the varying light from Algol doesn't know this - its light waves left Algol 93 years ago and are traveling at a constant speed relative to the aether. The result - we "catch a bunch of minima early" during August as shown on Chart 2. Exactly the opposite happens during February - the Earth is moving away from Algol that fast and it takes longer for the group of minima to reach us so we see them taking longer between events. How long? 7,379,039 km divided by the speed of light 299,792.458 km/sec is 24.61382 seconds - this rough calculation explains the deviations we see in Graph 2. So in May and November when we are not moving towards or away from Algol - the period seems constant. It is our rapid movement towards or away from the events in August and February that causes the timing differences.
Everything is worked in a single frame.
The hypothesis of varying speed of light must be tested by comparing measurements in different frames.
Do not put words in people's mouths.
Your substitution of constant speed with constant speed relative to the aether is (a) not justified, (b) not needed to explain the phenomena, and (c) does not explain the phenomena. You need to justify why you think the way do. Putting words in other people's mouths (or writing in this case) does not cut it.
I put that in there because it is clearly understood. Notice that it doesn't say..."the light from Algol slows down when we are heading towards it and speeds up when we are heading away from it in order to maintain a constant speed of c for the observers on the Earth."
I would like to point out something. Let us assume for a moment that SR is true and Algol is let's say 100.5 light-years away. Now then, if SR is true then the time required for light from emission to reception merely depends on the distance at the time of emission. Let's say that the Earth is closest to Algol in its orbit and there is an eclipse. Now then, the eclipse will arrive on Earth after Earth has made 100.5 orbits around the Sun. But after 100.5 orbits, the Earth is furthest away from Algol in its orbit. So the eclipses that occurred when the Earth was receding from Algol will start arriving on Earth as the Earth is approaching Algol. So we would have the bizarre effect of the eclipses being further apart in time as we are approaching Algol.
The time required for light to arrive depends on the location of the emitter at the time of emission and the location of the receiver at the time of reception.
The speed of light is constant in two senses:
(i) within one inertial frame in vacuum, the speed of light does not change over time.
(ii) in a frame moving at constant velocity relative to an inertial frame, the speed of light is the same as in the inertial frame.
In this example, sense (i) is being used; sense (ii) is not used since everything is worked in a single frame.
  • · Replies 26 ·
  • · Replies 25 ·
  • · Replies 43 ·
