Vector Addition and Displacement Magnitude in 3D Space
The discussion focuses on calculating the displacement vector from a base camp to a mountain summit, which is 2450m high and 4580m horizontally located at an angle of 32.4 degrees west of north. Participants express confusion about correctly visualizing the 3D coordinate system, particularly the placement of the z-axis and how to represent the height in relation to the horizontal displacement. Clarifications are provided that the z-axis is vertical, with the height of 2450m positioned between the x and y axes. The conversation highlights the challenges of visualizing 3D vectors and the importance of accurately drawing diagrams for better understanding. Overall, the thread emphasizes the complexities of vector addition and displacement in three-dimensional space.
jared69sib
The summit of a mountain, 2450m above the base camp, is measured on a map to be 4580m horizontally from the camp in a direction 32.4 degrees west of north. What are the components of the displacement vector from camp to summit? What is its magnitude? Choose the x-axis east, y-axis north, and z axis up.
vector r = i + j + k
I don't think I am drawing the diagram correctly. Not sure where to put z axis. I keep ending up with a triangle. x= 4580, y=2450, bottom angle 32.4...
hi jared69sib! :smile:
the z axis is up,
and the 2450 is between the x and y axes :wink:
the z axis is up,
Thank you. It was hard to visualize for the very first time.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
