Vector addition and Relative motion
The discussion revolves around vector addition and relative motion, specifically involving a boy on a raft in a river and the calculation of resultant velocities using vector components.
  • Participants explore the calculation of vector components for the boy's kicking and the resultant velocity of the raft. Questions arise regarding the identification of x and y components and the interpretation of vector diagrams.
Some participants have provided guidance on identifying vector components and suggested drawing vector diagrams to aid understanding. There is ongoing exploration of the calculations and some uncertainty remains regarding the correct approach.
Participants express difficulty in visualizing the problem and drawing vector diagrams, which are noted as fundamental to solving the questions posed.
nadong2dong
1) A boy is floating on a raft in a river. THe water flows at a speed of 12m/s east. The boy's feet kick the water,causing a velocity of 2m/s at an angle of 43 degrees north of east. Using Vector components, calculate the magnitude of the raft's velocity.
2)One vector has a magnitude of 20m/s and acts an angle of 25 degrees. The next vector has a magnitude of 12m/s and acts at an angle of 120 degrees. The final vector acts at an angle of 70 degrees and has a magnitude of 14m/s. Calculate the magnitude and the angle of the resultant vector.
1) 12xtan(43)= 11.19m/s
2)20m/s + 12m/s+ 14m/s = 46m/s?
25degree+ 120+ 70= 215degree...
1) 11.19m/s
2)46m/s and 215 degree?
Hello nadong2dong, welcome to PF! For part 1 (assuming east is +x and north is +y), the x-component of the river is clearly 12 m/s, and the y-component of the river is clearly 0 m/s. What x and y components can you come up with for the vector caused by the boy's kicking?
uhhh i don't quite understand what you are talking about
I get that x is 12 and y is 0, but what should i do to foind components caused by the boy's kicking
2sin(43)
2cos(43)?
When the question asks:
Do you get what the term "vector components" means?
nadong2dong said:
2sin(43)
2cos(43)?
Sure, but which is the x component? Which is the y component??
cos is the x component
and sin is the y?
It is very hard for me to picture the question in my mind.
Why don't you draw a vector diagram of what is going on?
that is the problem, i can't really draw a vector diagram for this question
and sin is the y?
Are you sure? Why the question mark? :smile: You happen to be right. Make sure you understand why you are right.
ok i got 13.53 m/s
Is that right?
nadong2dong said:
ok i got 13.53 m/s
Is that right?
That looks right, how did you get there?
square root of (2sin43)^2 + (2cos43 +12)^2
Alright, good work by you!
Well, [drawing vector diagrams] are fundamental to the solution of part 2. You should understand this this as soon as possible.
If your textbook does not cover this, get another textbook or search for online resources such as:
I'm done for the night. If someone else does not jump in, let's continue this later.
Thank You
