Vector addition - Finding V2 when V1 and V1+V2 are given
To find the second displacement vector (V2) when given the first displacement (V1) and the resultant vector (V1+V2), one must first resolve the known vectors into their x and y components. The equations Ax + Bx = Rx and Ay + By = Ry can be used to express the relationships between the components. By substituting the known values of V1 and the resultant vector, the unknown components of V2 can be calculated. This process simplifies the problem, allowing for the determination of both the magnitude and direction of V2. The discussion emphasizes the importance of breaking down the vectors into components for clarity in solving the problem.
exi
Particle has two displacements.
1 - 11m, 89 degrees
2 - ?
1+2 - 8.6m, 129 degrees
So:
1 = (11, 89°)
2 = ?
1+2 = (8.6, 129°)
X-component = M x cos(Θ)
Y-component = M x sin(Θ)
Total magnitude = sqrt((total x-component)² + (total y-component)²)
Total angle = tan-1 (total y-component / total x-component)
I'm not terribly sure how I should best try to find the magnitude and angle of the second portion of the movement here. I would've tried to solve for total magnitude, but I'm missing both X and Y components for #2, so... what should I do?
Of course you're missing those components--you have to solve for them! Set up an equation for x-components; from this you can solve for the unknown x-component of vector #2. Then do the same for the y-components.
Think this way:
1 + 2 = R
2 = R - 1
2 = R + (-1)
That's the thing. I'm probably making this far more complicated than it has to be, but the first idea or three that come to mind on how to do exactly that involve information that I don't have, like angles for #2.
I'd appreciate a kick-start on this one.
I'll call your vectors A and B (instead of 1 and 2). So you have:
A + B = R
You are given A and R; you need to find B. So solve for the components. Set up two equations:
(1) Ax + Bx = Rx
You should be able to compute and plug in the x-components of A and R. Then you can solve for Bx.
As Chi Meson explained:
Bx = Rx - Ax
(2) Ay + By = Ry
Same thing, only now you are doing the y-components.
So find Bx and By, then you can find the magnitude and direction of B.
perhaps setting up a table with assigning +x, -x, +y and -y to appropriate components would help you.
rest is just mathematical subtraction
A + B = R
(1) Ax + Bx = Rx
Bx = Rx - Ax
(2) Ay + By = Ry
Yep, I was definitely making this far more complicated than it was. For whatever reason, I kept thinking that it couldn't possibly be as easy as determining the component vectors of R and working out B from that.
Obviously, it is.
Thanks for the slap back into rational thinking o:)
  • · Replies 38 ·
14K
