Vector Addition Help: Find Resultant of 5 Vectors
The discussion focuses on calculating the resultant of five vectors using both graphical and numerical methods. The vectors are defined by specific angles and magnitudes, with the first vector being 20 degrees east of south for 1/2 inch, and others following similar specifications. The user initially calculated a resultant of 31.55 but faced confusion regarding the accuracy of their x and y component calculations. The correct approach involves using trigonometric functions to derive the components based on the angles provided, specifically using cosine and sine functions for each vector.
  • Understanding of vector components and their representation in a Cartesian coordinate system.
  • Familiarity with trigonometric functions, specifically sine and cosine.
  • Ability to perform vector addition both graphically and numerically.
  • Experience with graphing techniques and tools for visualizing vectors.
  • Learn how to calculate vector components using trigonometric functions in detail.
  • Explore graphical methods for vector addition, including the head-to-tail method.
  • Study the use of vector calculators or apps for accurate component calculations.
  • Investigate the implications of angle measurement in vector calculations, including quadrant considerations.
Students in physics or engineering, educators teaching vector analysis, and anyone interested in mastering vector addition techniques.
katieb123
Find the resultant for the following directions.
20 degrees east of south for 1/2"
80 degrees South of west for 5"
15 degrees west of north for 1"
35 degrees North of East for 3"
40 degrees South of East for 1"
R2 = a2 + b2
i graphed the measurements with each 5" = 1/2" on graph paper. then i connected the tail of the first vector to the head of the end point and measured the resultant but when i calculated it i got 31.55, to calculate this i found the x,y for each vector. vector 1- 4.69,-1.71. vector 2- - and -8.68, -49.24. vector 3- -9.66, 2.59. vector 4- 24.57, 17.21, vector 5- 8.19, -5.74. i added up the totals for each x and y then used the resultant formula to get the resultant to be 31.55. is that correct?
Show your calculations!
i showed calculations can you help?
31.55 was a value you measured on the graph paper, or was it a numerical calculation? Perhaps I'm not clear on what the point of the exercise is. Is the idea to find the resultant by graphical method or by numerical calculation? Or both?
Can you pick a vector, say vector 1, and show how you found the x and y components?
31.55 was found by calculations. i was asked to find both ways graphically and by calculator.
i found the vectors x, y by plugging it in my calculator in an app
Okay. I think your calculator app is giving you the x & y components in reverse order (or you're swapping them somehow), and they seem to be multiplied by 10.
If we take a Cartesian coordinate system where y is North and x is East, then for the first vector the angle is 20° East of South, which is -90° + 20° = -70°. The components are
x = (1/2)*cos(-70°) ; y = (1/2)*sin(-70°)
x = 0.1710 ; y = -0.4698
You should verify that your app gives you these results for the components of vector 1. After that, construct a table with the magnitude, angle, and components for each vector.
  • · Replies 16 ·
  • · Replies 19 ·
