Vector geometry - Intersection of lines
The forum discussion focuses on finding the intersection of two parametric vector equations representing lines: r(t) = (2,-4,4) + t(1,-3,4) and s(u) = (1,-1,0) + u(2,-1,1). The correct method involves equating the components of the vectors and solving for the parameters t and u. The intersection point is confirmed to be (1,-1,0) after proper substitution and solving. The discussion emphasizes that the parameters t and u do not need to be equal for the lines to intersect.
  • Understanding of parametric vector equations
  • Knowledge of vector component equality
  • Familiarity with solving linear equations
  • Basic concepts of vector geometry
  • Study the method of solving parametric equations for intersections
  • Learn about vector geometry and its applications in 3D space
  • Explore the concept of vector components and their equality
  • Investigate the use of different parameters for intersecting lines
Students studying vector geometry, mathematicians working on linear algebra, and anyone interested in solving parametric equations for line intersections.
Keshroom
I have 2 parametric vector equations (of a line)
s(t) = (1,-1,0) + t(2,-1,1)
how do i find the coordinates for which they intersect each other?
The answers is (1,-1,0)
x=a+λv, for some λ in ℝ (parametric vector form of line)
As in high school, with the form y=mx+b i would make the 2 equations equal to each other, solve for x, then substitute back into either equations to find y.
I've tried making the (x,y,z) components equal to each other, solve for 't' and substitute back in but i can't get the answer in the back of the book
parametic equations
for r(t): x = 2+t, y= -4-3t, z= 4+4t
for s(t): x = 1+2t, y= -1-t, z= t
Now i did
2+t = 1+2t
t = 1
substituting back into x=2+t: x = 3
i did this for also y and x components and got (3, 1/2, -4/3)
hmmmm
I have a feeling that this method isn't correct :s
Change the notation to
the parameters t and u don't have to be the same for the lines to intersect each other.
alright. Now how do i solve it?
The same way you tried before. Equate components of the vectors and solve them. Try it. The first component gives you 2+t=1+2u. Solve that for t and substitute into the rest.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 21 ·
