Vector magnitude and direction question
The discussion centers on calculating the components, magnitude, and direction of vector C, defined as vector A + vector B. The components of vector A are A x = 4 and A y = 2, while vector B has components B x = -3 and B y = -5. The resulting components of vector C are confirmed as C x = 1 and C y = -3, leading to a magnitude of 3.2. The direction calculation, initially attempted as -72 degrees, is corrected to a positive angle of 72 degrees, indicating a direction of "East 72 South."
  • Understanding of vector addition
  • Knowledge of trigonometric functions, specifically tangent
  • Familiarity with angle measurement in degrees and radians
  • Ability to interpret directional notation in vector analysis
  • Learn about vector addition and its geometric interpretation
  • Study trigonometric functions and their applications in vector calculations
  • Research angle conversions between degrees and radians
  • Explore directional notation in physics and engineering contexts
Students studying physics or mathematics, particularly those focusing on vector analysis and trigonometry, as well as educators looking for examples of vector component calculations.
Star Forger
Suppose vector C = vector A + vector B where vector A has components vector A x = 4, vector A y = 2 and vector B has components vector B x = -3, vector B y = -5.
(a) What are the x- and y- components of vector C ?
I've solved this to figure out that x = 1 and y = -3 for C
(b)What are the magnitude and direction of vector C ?
magnitude I've solved this to be 3.2
direction ? (clockwise from the x-axis) This is what I can't get. I've solved for the angle and gotten -72 degrees using tan -3/1. Does anybody know what I'm doing wrong?
Why do you say that answer is wrong. Perhaps you are not being accurate enough. 71 degrees, 35 minutes is slightly more accurate, 71 degrees, 34 minutes, and 36 seconds even more accurate. Or perhaps they want the answer in radians.
It's an online problem that checks itself when you put in the answer. It's telling me that my answer of -72 degrees is wrong and I'm not sure why. Also, it wants it in degrees specifically.
If X is 1 then that would be east, and given that the Y component is negative, its south.
I don't know the details of the question, but try East 72 South
Perhaps they want an answer between 0 and 360 degrees.
  • · Replies 16 ·
