Vector position, velocity, coordinates and speed
16 replies · 6K views · last reply
nerdalert21
A particle initially located at the origin has an acceleration of vector a = 5.00j m/s2 and an initial velocity of vector v i = 8.00i m/s.
a)Find the vector position at any time t (where t is measured in seconds). (Use the following as necessary: t.)
Find the vector velocity at any time t.
b)Find the coordinates of the particle at t = 2.00 s.
x=...m
y=...m
Find the speed of the particle at this time.
Not quite sure. Tried rf=ri+Vit+1/2at^2
Vf=Vi+at
For a) I plugged what i thought was right into the first equation above with ri=0i+0j because it is at the origin(see question) but the answer (8.00it+2.50jt^2) was wrong
Your answer to (a) looks fine to me. Why do you think it's wrong?
I would calculate the velocity of the object :
v(t) = [(8.00i)² + (5.00jt)²]^0.5 the i component remains constant where as the j component is accelerating from point of origin, so I am to assume that vj(0) = 0
and if you integrate v(t) from 0 to t you would get the position.
..or atleast this is how I understand the problem.
It's stated that you have to find the position vector as a function of time. you are correct writing R(0) = 0i + 0j , but this is for the displacement at time t = 0.
Think of this as a projectile motion in a gravitational field.
R here is a vector.
Your expression for v(t) is for the speed of the object, not its velocity. If you integrate it, you'd get the distance the object moved, not its displacement.
R here is a vector.
If you look more closely at what nerdalert21 wrote, you'll see i's and j's in the answer, which are the Cartesian unit vectors. (It would have helped a lot if the OP had used the typesetting features of the forum.) The answer ##\vec{r}(t) = (8.00t\,\hat{i} + 2.50t^2\,\hat{j})\text{ m}## is correct, so it's unclear why the OP thinks it's wrong. I'm guessing this is for web-based homework, and the OP somehow typed it in incorrectly.
I got a, I had messed up on typing the answer in.
For finding the vector velocity at any time t (a part2) can I use the equation Vf=Vi+at?
And then plug in the Vi, a and 0 for t?
Yes. You have the right idea for part 2, but they are asking for the velocity vector at an arbitrary time t, rather than at time t = 0.
Chet
Thanks for all your help guys, I've almost got the question done
The last part says to find the speed of the particle at time t=2
Thats solving for V right?
But I am confused on which equation i should use
You use your equation for the velocity vector evaluated at time t = 2, and then evaluate the magnitude of that vector to get the speed.
What do you mean by evaluate the magnitude?
Like, if i took the x and y components and put them like this:
R=√(x^2+y^2
Yup, but with the components of the velocity.
ok so for the velocity vector at any time t i got 8.00i+5.00jt
and the coordinates at t=2 are
x=16.00m
y=10.00m
So i tried the r=√16^2 + 10^2 and got 18.9 but it says the answer is wrong
Did i do that right?
Calculate the velocity vector at t=2 s. Then find the magnitude of that vector. ##\vec{r}## has nothing to do with the speed.
so i use Vf=Vi+at?
& I thought r is the magnitude?
Every vector has a magnitude and direction. If you're talking about the displacement vector, ##\vec{r} = x\,\hat{i}+y\,\hat{j}##, its magnitude ##r=\|\vec{r}\| = \sqrt{x^2+y^2}## would be the distance from the origin. If you're talking about the velocity vector, ##\vec{v} = v_x\,\hat{i}+v_y\,\hat{j}##, its magnitude ##v=\|\vec{v}\| = \sqrt{v_x^2+v_y^2}## would be the speed.
ohhh ok so it would be V=√(8^2+5^2)?
