How Is the Second Leg of the Triangle Calculated in Vector Problem?
  • Thread starter Thread starter NormalForce1
    Vector
The discussion centers on calculating the second leg of a triangle in vector problems, specifically using a scalene triangle with side lengths of 6360, 2700, and 3660. The resultant vector is identified as -6360, representing the distance a traveler must cover to return to the starting point. The angle was determined using the triangular sum theorem applied to a right triangle derived from the scalene triangle. The calculation of the second leg was questioned, with a suggestion that it equals 45 x 60 x 1.5.
  • Understanding of vector mathematics
  • Familiarity with the triangular sum theorem
  • Knowledge of scalene triangles and their properties
  • Basic trigonometry, particularly in right triangles
  • Research the application of the triangular sum theorem in vector calculations
  • Learn about the properties and calculations involving scalene triangles
  • Study the derivation of resultant vectors in physics
  • Explore trigonometric functions and their use in calculating angles and sides of triangles
Students and professionals in mathematics, physics, and engineering who are involved in vector analysis and triangle calculations.
NormalForce1
A student measures his own walking speed and discovers that it is 1.5 m/s. This student then plans a hike. He plans to start out by walking for 30 minutes due south at his usual constant speed. Then he will turn west slightly so that he is facing 35⁰ west of south, and he will walk (still at the same speed) for 45 minutes in that direction.
After he has completed this first 75 minutes of walking, If the student wants to walk back to where he started from, in what direction should he walk and how long will he need to walk for?
a^2 + b^2 = c^2
c^2 = sqrt{a^2+b^2-[2*a*b*cos(theta)]}
I tried finding the resultant vector which was -6360. The magnitude of -6360 is the distance the traveler must travel to reach the start.
I found the angle by using the triangular sum theorem on a right triangle that was split from a scalene triangle. The scalene triangle has side lengths of 6360, 2700, and 3660.
:welcome:
Do you have a question?
Where did you get 3660 from?
I agree with the 2700. Wouldn’t the second leg of the triangle equal 45 x 60 x 1.5?
  • · Replies 38 ·
  • · Replies 39 ·
  • · Replies 20 ·
12K
