Vector Question -- |A+B| is 78 times greater than |A-B|
  • Thread starter Thread starter smakhtar
    Vector
The problem involves two vectors, A and B, which have the same magnitude. The relationship between the magnitudes of the sum and difference of these vectors is given, specifically that |A+B| is 78 times greater than |A-B|. Participants are exploring the implications of this relationship, particularly focusing on the angle between the vectors.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss using the dot product and geometric interpretations to derive equations related to the magnitudes of the vectors. There are attempts to simplify equations by substituting equal magnitudes for A and B. Questions arise regarding the correct application of the given ratio and the implications of squaring the 78 value in the equations.
The discussion is ongoing, with participants providing various algebraic manipulations and questioning the correctness of their approaches. Some guidance has been offered regarding alternative methods to simplify the problem, but no consensus has been reached on the correct path forward.
Participants note the requirement that the vectors A and B have equal magnitudes, which influences their calculations. There is also mention of potential missing information or assumptions regarding the angle between the vectors and how it affects the equations derived.
smakhtar
Vectors A and B have the same magnitude. |A+B| is 78 times greater than |A-B|, for this to happen, what must be the angle between vectors A and B?
78((A^2) + (B^2)-2ABcos(theta))=((A^2)+(B^2)+2ABcos(theta))
Made it by using dot product.
What I did was used dot product and got 78((A^2) + (B^2)-2ABcos(theta))=((A^2)+(B^2)+2ABcos(theta)). And I let B=A because they have the same magnitude. I simplify this equation further and cancel things out and I got the wrong answer. The answer I got is 12.9 deg. What did I do wrong?
Sketch out the addition and subtraction by head-to-tail.
You can use geometry (i.e. the cosine rule) on the two triangles to find the lengths of A+B and A-B.
The requirement that |A+B|/|A-B|=78 gives the third equation you need to solve the system.
So I got (x^2)=(A^2)+(B^2)-2AB(cos180 - theta)
and 78(x^2)=(A^2)+(B^2)-2ABcos(theta)
I rearranged for x in the first equation, and subbed that into the second, made B=A because they have the same magnitude. I canceled out the A's, and I got to 78(2+theta)=1-cos(theta). How do I solve for theta when there is theta alone and theta with cos?
By the way, before going much further, shouldn't we be squaring the 78 value somewhere along the way?
[e.g., (78x)2 = 782x2]
... well you could have divided the second equation by the first one rather than substitute - it's algebraically easier.
... but if x=|A+B|, then shouldn't the second equation start out (x/78)^2 ... ?
You also simplify by putting |A|=|B|=a
You still get something that looks a bit like what you got - just a tad tidier.
To simplify - follow your nose: solve for cosθ and take the inverse.
How does |A+B| relate to (A+B) dot (A+B) ? Are they equal?
You should find it pretty easy to verify that C·C=|C|2 for all vectors C. In particular, this means that |A+B| is the square root of (A+B)·(A+B).
  • · Replies 16 ·
10K
