Finding the Vertex of a Translated Curve
  • Thread starter Thread starter Trail_Builder
    Confusion Vector
The discussion revolves around finding the vertex of a translated curve, specifically a parabola with the equation y = f(x) that passes through the origin and has a vertex at (2, -4). Participants clarify that the term "translated" refers to shifting the graph without stretching or rotating it. The correct equation for the translated parabola is identified as y = f(x) = (x - 2)² - 4, confirming that the vertex remains at (2, -4) with no vertical stretching. The confusion initially stemmed from the use of the term "vector," which was deemed inappropriate for this context. Overall, the key takeaway is understanding how to derive the equation of a translated parabola based on its vertex.
Trail_Builder
hi, I'm basically a bit confused as to how to solve this vector question, in other words, in what i have to do which is confusing me...
This is a sketch of the curve with equation y = f(x)
It passes through the origin O.
(the sketch has no value on or anything, its simply a happy parabola then passes through the origin on the left side a bit of the way up, and dips in the negative y values)
The only vertex of the curve is at A (2, -4)
a) Write down the coordinates of the vertex of the curve with the equation (bold are my answers)
i) y = f(x-3) (5, -4)
ii) y = f(x) -5 (2, -9)
iii) y = -f(x) (2, 4)
iv) y = f(2x) (1, -4)
The curve with equation y=x^2 has been translated to give the curve y=f(x)[/]
b) find f(x) in terms of x
(I don't know if the first half of the question is needed, if it is, say so and ill post it up)
not really sure, i know how functions work, I know all about vectors too, but not sure what it means by "translated", and how i would find out the answer.
my instinct says the answer is simply x^2, but somehow I don't think it is, and i certainly don't think that is worthy of 4 marks :S
hope you can help, thnx
i added in the entirity of the question now..
Translated how? The question as posted doesn't make much sense. Better post the rest.
ok
ill add it to the main topic
added to the topic the entirity of the question, hope that helps
Ok, so y=f(x) is a parabola going through the origin with a vertex at (2,-4) and you want to find its equation given that its a translation of y=x^2? Well, you want to move it two units right and four units down. Having done part a) you should be able to manage that. What's your guess?
That, together with the fact that it is a "happy" (I like that!) parabola with vertex (2, -4) tells you that y= a(x-2)2- 4 for some positive number a.
Okay, that tells you that the "a" above is 1!
From the first statement, that this is a parabola opening upward with vertex (2, 4), you know the equation is y= a(x-2)2+ 4. Now you know that a= 1!
o rite, see how the answer is y=f(x-2)+4 now, but one thing i a tad confused on
the a you refer to, that's the stretching and stuff yeh, and just to check, is the reason you came to the conlusion that it has to be 1, because it said y = x^2 is translated. does that term translated refer specificially to it moving not being strechted or whatever?
thnx for the help
Yes, in connection with movement (as opposed to translating a language!) means a movement with no stretching or rotating.
By the way, why did you title this "vector question confusion" (and refer to it as a "vector question" in your post) when there are no vectors involved?
oops haha, yeh i realized what i did
basically, i was stuck writing a vector problem in the topic, but then i figured out what i was doing, then went onto to the next question (this question), and forgot to change the topic title hehe
oops
  • · Replies 23 ·
