Vector Spaces - The Exchange Theorem - Cooperstein Theorem 1.16
7 replies · 3K views · last reply
Math Amateur
MHB
I am reading Bruce Cooperstein's book: Advanced Linear Algebra ... ...
I am focused on Section 1.6 Bases and Finite-Dimensional Vector Spaces ...
I need help with the proof of Theorem 1.16 ...
Theorem 1.16 and its proof reads as follows:
Question 1
In the second paragraph of above proof we read the following:
"... ... Since $$y_1 \neq 0$$ it follows ... ... Can someone please explain exactly why $$y_1 \neq 0$$?Question 2
"... ... By reordering the vectors of $$X$$, we can assume that $$x_n$$ is a linear combination of $$Z_1 = ( y_1, x_1, \ ... \ ... \ , x_{n-1}$$. ... ... "
Can someone explain (in some detail) exactly why $$x_n$$ is a linear combination of $$Z_1 = ( y_1, x_1, \ ... \ ... \ , x_{n-1}) $$?
Hope someone can help ... ...
Help will be much appreciated ... ...
Peter
NOTE: The text from Cooperstein displayed above mentions Theorem 1.14 ... so I am providing the statement of Theorem 1.14 as follows:View attachment 5135
Hi Peter,
In the proof, we are assuming that $Y$ is linearly independent, so it can't contain null vectors.
Peter said:
Can someone explain (in some detail) exactly why $$x_n$$ is a linear combination of $$Z_1 = ( y_1, x_1, \ ... \ ... \ , x_{n-1}$$?
Once you have noted that $y_{1}\in Span(X)$ you have that $y_{1}=\displaystyle\sum_{i=0}^{m}c_{i}x_{i}$ for some $c_{i}\in K$ (being $K$ the field under your vector space $V$).
Now, since $y_{1}\neq 0$ there is at least one non zero coefficient in the above sum, say $c_{j}$.
Can you then imagine how $x_{j}$ is a linear combimation of $x_{i}$, with $i\neq j$ and $y_{1}$?
If you can do that, the rest is just taking a different order in the indices.
By assumption you start with a lin. ind. set, therefore no vector in it can be zero. (Or show that if you have a list of vectors, and a zero vector is among them, then that list is automatically lin. dep.)
It is crucial, when talking about bases, to thoroughly wrap one's mind around the concept of linear independence, and linear dependence.
A finite set $S = \{v_1,v_2,\dots,v_k\} \subset V$ of vectors in a vector space $V$ over a field $F$ is said to be linear dependent if there exist scalars $c_1,c_2,\dots,c_k \in F$ not all zero such that:
$c_1v_1 + c_2v_2 + \cdots + c_kv_k = 0_V$
In particular, if $c_j \neq 0_F$, then:
$v_j = -\dfrac{c_1}{c_j}v_1 - \cdots -\dfrac{c_{j-1}}{c_j}v_{j-1} - \dfrac{c_{j+1}}{c_j}v_{j+1}-\cdots-\dfrac{c_k}{c_j}v_k$
that is, $v_j \in \text{span}(S - \{v_j\})$, so we have some "redundancy" in $S$ as a spanning set of $\text{span}(S)$.
As an easy consequence, we can prove, straight from the definition:
for any finite set $S \subset V$ such that $0_V \in S$, $S$ is a linearly dependent set.
Proof: re-label the set $S$ like so: $\{v_1,v_2,\dots,v_{k-1},0_V\}$. Choose $\{c_1,c_2,\dots,c_{k-1},c_k\}$ in the following way:
$c_1 = c_2 = \cdots = c_{k-1} = 0_F$, and $c_k = 1_F$.
Since $F$ is a field, $0_F \neq 1_F$, and our set of $c$'s is not all zeros (it has one non-zero element).
Then $c_1v_1 + \cdots + c_{k-1}v_{k-1} + c_k 0_V = 0_Fv_1 + \cdots + 0_Fv_{k-1} + 1_F0_V$
$= 0_V +\cdots + 0_V + 1_F0_V = 1_F0_V = 0_V$.
Linear independence is the negation of the property of linear dependence. Since linear dependence asserts the existence of a certain set of non-zero scalars that produce a 0 linear combination, linear independence asserts that for all such non-zero sets, they never produce a 0 linear combination. We can restate this as:
A finite set $S = \{v_1,\dots,v_k\} \subset V$ is linearly independent if:
$c_1v_1 + \cdots + c_kv_k = 0_V \implies c_1 = \cdots = c_k = 0_F$.
If a (finite) set $S$ is linearly independent, *all* the elements of $S$ are necessary to generate $\text{span}(S)$. For if $v_j \in S$, there is no way to realize $v_j$ as a linear combination of the other elements of $S$ (for if so, if we could write:
$v_j = d_1v_1 + \cdots + d_{j-1}v_{j-1} + d_{j+1}v_{j+1} + \cdots + d_kv_k$
then we would have:
$d_1v_1 + \cdots + d_{j-1}v_{j-1} - 1_Fv_j + d_{j+1}v_{j+1} + \cdots + d_kv_k = 0_V$, and the set:
$\{d_1,\dots,-1_F,d_{j+1},\dots,d_k\}$ is not all zero elements of $F$ ($-1_F$ cannot be zero, do you see why?). This contradicts the linear independence of $S$).
These ideas can be extended to infinite sets, as well, if we only allow *finite* linear combinations. But there are certain subtleties involved which are better left alone, for now (for finite-dimensional vector spaces, you will not need to examine infinite generating sets).
Thanks Fallen Angel and ThePerfectHacker ... appreciate the help ...
Peter
- - - Updated - - -
then we would have:
Thank you, Deveno, for a particularly helpful post ... really appreciate your help ...
Peter
Peter
- - - Updated - - -Thank you, Deveno, for a particularly helpful post ... really appreciate your help ...
Peter
There is another point that I am not quite clear on regarding Cooperstein's proof ... so for convenience of MHB readers I will provide the text of the Exchange Theorem and its proof again ...https://www.physicsforums.com/attachments/5138In the above text, we read the following:
"... ... Since we are assuming that $$x_n \in \text{Span} (Z_1)$$, it follows that $$\text{Span} (Z_1) = \text{Span} (X) = V$$ ... ... Can someone please explain exactly why $$x_n \in \text{Span} (Z_1)$$ implies that $$\text{Span} (Z_1) = \text{Span} (X) = V$$?
Help will be appreciated ... ...
Peter
Peter said:
There is another point that I am not quite clear on regarding Cooperstein's proof ... so for convenience of MHB readers I will provide the text of the Exchange Theorem and its proof again ...In the above text, we read the following:
Peter
If $\{y_1,x_1,\dots,x_n\}$ is linearly dependent, there is some NOT ALL ZERO $c_j$ for $j = 1,2,\dots,n,n+1$ such that:
$c_1x_1 + c_2x + \cdots + c_nx_n + c_{n+1}y_1 = 0$
Now, if $c_j = 0$ for all $j = 1,2,\dots,n$ (only the first $n$), we are left with:
$c_{n+1}y_1 = 0$, and since our $c_j$ were assumed not ALL zero, we would have $c_{n+1} \neq 0$, forcing $y_1 = 0$.
But $0$ cannot be part of any linearly independent set (see my previous post), so this possibility violates our assumption that $Y = \{y_1,\dots,y_{n+1}\}$ is linearly independent.
So for $Y$ to be linearly independent, we have to have one of the "earlier" $c_j$ be non-zero. It doesn't really matter which one, for the sake of ease in writing the subscripts, we assume without loss of generality it is $c_n$ (if it isn't actuallty $c_n$, we can just re-arrange the $x_i$).
But then this gives:
$c_nx_n = -c_1x_1 - \cdots - c_{n-1}x_{n-1} - c_{n+1}y_1$
and since $c_n \neq 0$, we can divide both sides by it, to explicitly get $x_n$ as a linear combination of $\{y_1,x_1,\dots,x_{n-1}\}$.
Thus any element of $\text{span}(X)$, that is:
$a_1x_1 + \cdots + a_nx_n$ is equal to:
$a_1x_1 + \cdots + a_{n-1}x_{n-1} + a_n\left( -\dfrac{c_1}{c_n}x_1 - \cdots - \dfrac{c_{n-1}}{c_n}x_{n-1} -\dfrac{ c_{n+1}}{c_n}y_1\right)$
$= \left(a_1 - \dfrac{a_nc_1}{c_n}\right)x_1 + \cdots + \left(a_{n-1} - \dfrac{a_nc_{n-1}}{c_n}\right)x_{n-1} - \dfrac{a_nc_{n+1}}{c_n}y_1$,
which is an element of $\text{span}(Z_1)$, so $\text{span}(X) \subseteq \text{span}(Z_1)$.
The other inclusion is obvious, since $\text{span}(X) = V$, and any linear combination of elements of $V$ is contained in $V$, by the closure axioms of a vector space.
Thanks for for the help Deveno ... much appreciated ...
... working through the the detail of your post now ...
Thanks again,
Peter
