Vector Triple Product - Physcial Significance
2 replies · 5K views · last reply
RanchodDasChanchad
Hii,
As we know, Scaler triple product is volume of parallelopiped constructed by its three sides.
Similary,
What is the physical significance and geometrical interpretation of Vector triple product ?
Also, What are the application where we use such mathematics and why ?
Regards,
Rahul
A good question. Since the cross product ##\vec v \times \vec w## is a vector orthogonal to both ##\vec v## and ##\vec w##, the product ##\vec v \times (\vec w \times \vec u)## is a vector that is orthogonal to both ##\vec v## and ##\vec w \times \vec u##. As such, it lies in the plane spanned by ##\vec w## and ##\vec u## (since ##\vec w## and ##\vec u## are orthogonal to ##\vec w \times \vec u##). Now, this becomes particularly interesting when ##\vec u = \vec v##, since the result must be then be a linear combination of ##\vec v## and ##\vec w## at the same time as it is orthogonal to ##\vec v##, which leaves only one possible direction. Let us see what use we can put this to.
Consider the case when ##\vec v = \vec n## is a normalised vector of length one, i.e., ##\vec n^2 = 1## and take the triple product
\vec n \times (\vec w \times \vec n) = \vec w (\vec n^2) - (\vec n \cdot \vec w) \vec n = \vec w - (\vec n \cdot \vec w) \vec n,
where we have applied the bac-cab rule. Rearranging this leads to the relation
\vec w = \vec n (\vec w \cdot \vec n) + \vec n \times (\vec w \times \vec n).
You may recognise the first term on the right as the projection of ##\vec w## on ##\vec n##. As both terms add up to ##\vec w##, it should therefore be clear that ##\vec n \times (\vec w \times \vec n)## is the component of ##\vec w## orthogonal to ##\vec n##. One common use of the vector triple product is therefore to find the orthogonal component of a vector with respect to another.
Ah yes, we can also add that the particular linear combination of ##\vec b## and ##\vec c## that ##\vec a \times (\vec b \times \vec c)## is given by can be found through the bac-cab-rule
\vec a \times (\vec b \times \vec c) = \vec b (\vec a \cdot \vec c) - \vec c (\vec a \cdot \vec b).
Clearly this is a vector that is in the plane spanned by ##\vec b## and ##\vec c##. Furthermore, the orthogonality to ##\vec a## is apparent (dotting ##\vec a## into the expression gives two terms with the same size and opposite signs).
