Figuring Out Spanning w/ Vectors of 3 Components
  • Context: Undergrad
  • Thread starter Thread starter DmytriE
    Vectors
This discussion focuses on determining if a vector \( w \) is in the span of three given vectors \( v_1, v_2, v_3 \) in three-dimensional space. The span is defined as the set of all linear combinations of the vectors, expressed as \( w = a v_1 + b v_2 + c v_3 \). To find coefficients \( a, b, c \), one must solve a system of linear equations derived from the components of the vectors. The determinant of the transition matrix formed by the coefficients can indicate whether a solution exists, with a non-zero determinant confirming that the vector is in the span.
  • Understanding of linear combinations in vector spaces
  • Familiarity with solving systems of linear equations
  • Knowledge of determinants and their properties
  • Basic concepts of linear algebra, particularly vector spans
  • Study how to calculate determinants of matrices, particularly 3x3 matrices
  • Learn about the properties of linear independence and dependence
  • Explore methods for solving systems of equations, including Gaussian elimination
  • Investigate the geometric interpretation of vector spans in three-dimensional space
Students of linear algebra, educators teaching vector spaces, and anyone interested in understanding the concepts of vector spans and linear combinations.
DmytriE
If you are given three vectors (v1, v2, v3) that each have 3 components (i.e. x, y, z) how do you go about figuring out if vector w is in the subspace that is spanned by v1, v2, v3?
I know that span is the sum of scalar multiples of vectors for example:
αv1 + βv2 + γv3
I am brand new to linear algebra and our professor decided to start in chapter 4 rather than from the beginning.
Thanks for your help!
There is nothing else you can do then actually finding the a,b and c such that
w=av_1+bv_2+cv_3
For example, (1,2,4) is in the span of (1,1,1),(0,1,1) and (0,0,1) because
(1,2,3)=(1,1,1)+(0,1,1)+2(0,0,1).
So take a=b=1 and c=2.
The hard problem is actually finding the a,b and c. There are a couple of trick to do that.
For example, let's say you have (4,1,6) and you want to see if it is in the span of (2,6,1), (4,1,2) and (6,6,4). So you need to find a,b and c such that
(4,1,6)=a(2,6,1)+b(4,1,2)+c(6,6,4)=(2a+4b+6c,6a+b+6c,a+2b+4c)
This means you have to solve the following system of equations:
\left\{<br /> \begin{array}{l}<br /> 2a+4b+6c=4\\<br /> 6a+b+6c=1\\<br /> a+2b+4c=4<br /> \end{array}<br /> \right.
If this system has a solution (a,b,c) and these are the a,b and c you are looking for. If the system has no solution, then (4,1,6) is not in the span of the three vectors.
Thank you! :-) That is exactly what I was looking for. I didn't want to post the homework question mainly because I wanted to understand the concept and then apply it.
Perhaps it's a good idea to make some exercises on the concept. Make up your own vectors and see if you can do it.
Just an idea. You do what you want! :-p
There is actually a trick that can give a simple formula to know if there is a solution or not.
This is based on observing that the equation set micromass showed near the end of her post is very similar for different vectors: only the numbers on the right side of the equals sign change.
The numbers on the left hand side are usually called "the transition matrix of v1,v2,v3". That is, all 9 of them together as a block. Now the determinant of this matrix can tell you if there are solutions are not. This is more advanced material, and will probably be covered later in your course.
I am intrigued. I looked at the wikipedia page that you linked to but am confused by the terminology that they used. When taking the determinant of matrix A what value will represent whether the vector in question is part of the span?
In general, given a system (I'll do a 3x3 system, but it can be any nxn system):
\left\{\begin{array}{l} ax+by+cz=d\\ ex+fy+gz=h\\ ix+jy+kz=l \end{array}\right.
This system can be written in following form
\left(\begin{array}{ccc} a &amp; b &amp; c\\ e &amp; f &amp; g\\ i &amp; j &amp; k \end{array}\right)\left( \begin{array}{c} x\\ y\\ z\end{array}\right) = \left(\begin{array}{c}d\\ h\\ l\end{array}\right)
which I will write as A\mathbf{x}=\mathbf{b}. If the matrix A is invertible, then this has a unique solution \mathbf{x}=A^{-1}\mathbf{b}. (of course we need A to be invertible in order for A^{-1} to exists).
However, a matrix is invertible if and only if its determinant is nonzero.
So we have now shown that the system above has a solution if its determinant is nonzero.
If \mathbf{b}=0 (so if d=h=l=0) then the converse also hold: the system has a solution if and only if the determinant is nonzero.
20K
