But, as I said, you don't actually need the coordinates at all.
To calculate |u+v+w| for vectors u, v, and w, where |u|=√2, |v|=√3, and u is perpendicular to v, it is established that w=u×v has a magnitude of |w|=√6. The calculation of |u+v+w| can be approached without assuming specific vector coordinates by utilizing the properties of orthogonality. By expanding the square of the vector sum, it is shown that all inner products are zero due to orthogonality, leading to the conclusion that |u+v+w|=√11. This method confirms that the result holds true regardless of the coordinate system used.
hnnhcmmngs
Calculate |u+v+w|, knowing that u, v, and w are vectors in space such that
|u|=√2, |v|=√3, u is perpendicular to v, w=u×v.
|w|=|u×v|=|u|*|v|*sinΘ
[/B]
Θ=90°
|w|=(√2)*(√3)*sin(90°)=√(6)
Then I tried to use
u={√2,0,0}
v={0,√3,0}
w={0,0,√6}
and I got that |u+v+w|=√(2+3+6)=√11
but I'm trying to find a way to do this problem where I don't assume that those are the vectors.
[/B]
Θ=90°
Then I tried to use
u={√2,0,0}
v={0,√3,0}
w={0,0,√6}
There is no loss of generality in what you did. Assuming that ##u,v,w## are vectors in some Cartesian coordinate system ##(x,y,z)##, just change coordinates to a new system ##(x', y', z')## in which ##u## points along the ##x'##-axis, ##v## points along the ##y'##-axis and ##w## points along the ##z'##-axis. That takes you right back to your original calculations.
Note added in edit: that argument assumes that the cross-product ##u \times v## behaves like a vector under a rotation; that is, if ##{\cal R}## is a rotation, then ##{\cal R}(u \times v) = {\cal R} u \: \times \: {\cal R} v.## (Here I mean that ##{\cal R} u## is the vector ##u## re-expressed in a new coordinate system obtained by applying ##{\cal R}## to the original unit coordinate vectors ##e_x, e_y, e_z##; it does not mean that the "physical" vector ##u## is rotated.) That "rotation" result is true, but needs to be proved, a task I will leave to you.
Likes FactChecker
However, it should be noted that you can do it without ever referring to a coordinate system at all, just square and expand the vector sum:
(\vec u + \vec v + \vec w)^2 = \vec u^2 + \vec v^2 + \vec w^2 + 2 (\vec u \cdot \vec v + \vec u \cdot \vec w + \vec v \cdot \vec w).
Now, all of the inner products in the parenthesis are zero because all of the vectors are orthogonal. Furthermore
\vec w^2 = (\vec u \times \vec v)^2 = (\vec u \times \vec v)\cdot(\vec u \times \vec v)
= -\vec v \cdot [\vec u \times (\vec u \times \vec v )].
Apply the BAC-CAB rule:
\vec w^2 = -\vec v \cdot [\vec u (\vec u \cdot \vec v)- \vec v (\vec u^2)] = \vec v^2 \vec u^2 = 6.
It follows that
(\vec u + \vec v + \vec w)^2 = 2+3+6 = 11.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 16 ·
11K
