Vectors with appl of dot product
3 replies · 3K views
teknodude
I'm trying to solve this problem with different approaches. Link is here
http://img138.imageshack.us/img138/2268/problem1eb1.th.png
the answer is 0i + 0.0927j + 0.0232 k lb* Means DOT
Method one: Find the force in scalar components. Then Take the cross product of two position vectors to get a normal vector (V) to the surface. THen take the unit vector of V. Then F(normal) = (V*F)V
THis method worked F(normal)= 0i + 0.0927j + 0.0232 k lb
Method 2: Find the force in scalar components. Draw a perpendicular line to the surface and by similar triangles the normal vector V is 8j + 2k. Take the units vector of V. Then F(normal) = (V*F)V
Method 3: This one i tried taking a position vector along the surface like from point A to point J. Position vector AJ = 0i-1j+4k. THen getting of units vector, unit vector eAJ = 0i - 0.2425j + 0.9701k.
THen F(parallel)= (eAJ*F)eAJ
F(normal) = F- F(parallel)
F(normal) = -0.1231 i + 0.0927j + 0.0232 k lb
THe only difference is the x-component, which differs a little. Is this answer still right? I didn;t round any numbers when calculating.
The normal to that surface would by definition have no x-component, so the Method 3 answer is wrong. I'm not understanding what you are trying to do in that method, so I'm not able to figure out what is wrong.
Almost forgot about this.
Here's the work that I did for method 3.
The manner in which you obtain the F (parallel) is incorrect. The direction of F (parallel) is not simply AJ just because AJ lies on the surface of the slope.
To visualize F (parallel), try imagining the shadow of the string on the sloped surface if a light source is at some point above (though not exactly) the string.
