Solve Velocity 4-Vector Homework
  • Thread starter Thread starter MikeLizzi
    4-vector Velocity
The discussion revolves around solving a homework problem involving the transformation of velocity using 4-vectors in the context of special relativity. The initial conditions include the space-time coordinates and velocities of an object and a target reference frame. Participants clarify the 4-vector technique, emphasizing the importance of the Lorentz transformation equations and the gamma factor. One user expresses confusion but ultimately finds clarity through shared insights and LaTeX formatting, leading to a successful understanding of the problem. The conversation highlights the collaborative nature of learning complex physics concepts.
MikeLizzi
Given
Space Time Coordinate of object <t, x, y, z> = <0, 0, 0, 0>
Velocity of object as Vector <betaX, betaY, betaZ> = <.866, 0 ,0>
Velocity of target reference frame as Vector <betaX, betaY, betaZ> = <-.866, 0 ,0>
Transform velocity of object to the target reference frame using the 4-vector technique.
[/B]Following directions from a source on the internet...
Velocity as a 4-vector (tau, vx, vy, vz)
= <1, betaX, betaY, betaZ>
= <1, 0.866, 0.0, 0.0>
magnitude of 4-vector
= Sqrt( 1 + betaX * betaX + betaY * betaY + betaZ * betaZ )
= 1.3228590249909473
Velocity as a 4-vector normalized (tau, x, y, z)
= <1/magnitude, betaX/magnitude, betaY/magnitude, betaZ/magnitude>
= <0.7559384493044097, 0.6546426970976188, 0.0, 0.0>
Transform the 4-vector where L is the Lorentz Transform populated for the target velocity:
v' = Lv
resulting in v'(tau, x, y, z)
= <2.6454852575216505, 2.6183403845739543, 0.0, 0.0>
? I should be getting a vx value somewhere around .98c. Totally lost.
If you think you're totally lost, I'm lost trying to figure out what you're doing. First, I suggest stating what the 4-vector technique is. Is that the Lorentz transformation of 4-vectors? Perhaps you could state the relevant transformation equations?
To give a start and also help you with some latex. If a particle has a velocity ##u## in the x-direction with gamma factor ##\gamma_u##, then its four-velocity is:
##(u_{\mu}) = (\gamma_u, \gamma_u u, 0,0)##
That helps a lot. I am going to spend some time working the problem (and my latex).
I think I got it!
It took a couple days to learn latex but PeroK's hint and seeing the formulas clearly made me realize what I was doing wrong.
Here's the latex by the way (still working on format)
The Lorentz Transformation is defined as
$$\lambda=
\begin{bmatrix}
\gamma & -\gamma\beta_x & -\gamma\beta_y & -\gamma\beta_z \\
-\gamma\beta_x & 1+\frac{(\gamma -1)\beta_x^2}{\beta^2} & \frac{(\gamma -1)\beta_x\beta_y}{\beta^2} & \frac{(\gamma -1)\beta_x \beta_z}{\beta^2} \\
-\gamma\beta_y & \frac{(\gamma -1)\beta_x\beta_y}{\beta^2} & 1+\frac{(\gamma -1)\beta_y^2}{\beta^2} & \frac{(\gamma -1)\beta_y\beta_z}{\beta^2} \\
-\gamma\beta_z & \frac{(\gamma -1)\beta_x\beta_z}{\beta^2} & \frac{(\gamma -1)\beta_y\beta_z}{\beta^2} & 1+\frac{(\gamma -1)\beta_z^2}{\beta^2}
\end{bmatrix}
Where v is the velocity of S with respect to S' and
$$\beta_x = v_x/c$$
$$\beta_y = v_y/c$$
$$\beta_y = v_y/c$$
$$\beta^2 = \beta_x^2 + \beta_y^2 + \beta_z^2$$
$$\gamma = \frac{1}{\sqrt{1-\beta^2}}$$
The velocity 4-vector in reference frame S' is defined as
$$u'_\mu=
\begin{bmatrix}
\gamma_{u'} \\
\gamma_{u'} u'_x \\
\gamma_{u'} u'_y \\
\gamma_{u'} u'_z
\end{bmatrix}
Where u' is the 3-vector velocity of an object with respect to the S' reference frame and gamma is the gamma value using u'.
The velocity 4-vector in reference frame S is defined as
$$u_\mu=
\begin{bmatrix}
\gamma_{u} \\
\gamma_{u} u_x \\
\gamma_{u} u_y \\
\gamma_{u} u_z
\end{bmatrix}
Where u is the 3-vector velocity of an object with respect to the S reference frame and gamma is the gamma value using u.
Thanks PeroK !
  • · Replies 17 ·
  • · Replies 25 ·
