Velocity Potential of a Moving Cylinder
The discussion focuses on deriving the velocity potential of a moving 2D cylinder in potential fluid, specifically when the cylinder moves in the negative x-direction with velocity U(t). It establishes that the flow around a moving cylinder and the flow past a stationary cylinder are equivalent when viewed from different reference frames. The key conclusion is that the velocity potential must satisfy boundary conditions, including that the fluid remains stationary at far distances and that the fluid velocity at the cylinder's surface matches the cylinder's velocity. The concept of Galilean invariance is crucial in proving the similarity of solutions in different frames.
  • Understanding of potential flow theory
  • Familiarity with boundary conditions in fluid dynamics
  • Knowledge of Galilean invariance in physics
  • Basic calculus for deriving velocity potentials
  • Study the derivation of velocity potentials in potential flow theory
  • Learn about boundary conditions specific to fluid dynamics
  • Explore Galilean invariance and its applications in fluid mechanics
  • Investigate the mathematical formulation of fluid flow around cylinders
Fluid dynamics students, researchers in potential flow theory, and engineers working on fluid mechanics problems involving moving bodies.
dimasmr21
Hi, i need help in deriving the velocity potential of a moving 2D cylinder (circle) in potential fluid.
The cylinder is moving in negative x direction U(t).
I can derive the velocity potential of fluid past a cylinder (cylinder is stationary, in which it is the scalar summation of uniform flow, and a doublet). But i don't know how to derive the potential for a moving cylinder.
My simple thoughts were:
a.) There is no need to use a uniform flow potential.
b.) The velocity potential shall be in term of U(t), or -dx/dt.
Please kindly help me. Thank you so much.
The flow of a fluid moving past a cylinder and the flow around a cylinder moving through a stationary fluid are identical. They just use different reference frames. If the velocity of the cylinder is ##-U_{x}\hat{x}##, then in the frame of the cylinder, you can assume the cylinder to be at rest and the far-field velocity of the fluid to be ##U_{x}\hat{x}##.
Thank you so much for your reply. That is my objective. I mean i have to prove that the "pressure distribution" shall be the same.
During the process, i managed to understand that the velocity potential must satisfy two boundary condition (this is what i wrote on my report).
  1. Fluid at the far region from the cylinder shall remain stationary (no flow, or one can simply say that the fluid velocity at the far region is zero)
  2. If one “moves” along with the cylinder, he shall have the same velocity as the cylinder. One can simply interpret that the fluid velocity at every point on cylinder surface is equal to the cylinder velocity.
My problem right now is, i can't seem to derive it in a scientific manner (as i have already found the velocity potential by trial and error (lol) which satisfied the boundary condition).
Thank you, i hope you can help me! :)
The proof that the two solutions are similar is enforced by Galilean invariance which states that the laws of motion (including fluid motion) are identical in all reference frames. If the fluid velocity in the frame of the moving cylinder is given by ##U'(\mathbf{x}',t)## then the fluid velocity ##U(\mathbf{x},t)## in the rest frame of the fluid is
$$U(\mathbf{x},t)=U'(\mathbf{x}',t)+\mathbf{v}$$
where ##\mathbf{v}## is the velocity of the moving cylinder and
$$\mathbf{x}'=\mathbf{x}-\mathbf{x}_{0}-\mathbf{v}t$$
where ##\mathbf{x}_{0}## is the initial location of the cylinder in the stationary frame.
The potential ##\phi(\mathbf{x},t)## likewise undergoes the transformation
$$\phi(\mathbf{x},t)=\phi'(\mathbf{x}',t)$$
  • · Replies 45 ·
  • · Replies 24 ·
  • · Replies 51 ·
9K
  • · Replies 19 ·
