Velocity-time graph from distance-time table
The discussion revolves around interpreting a distance-time table to create a velocity-time graph, focusing on the clarity of terms like distance versus displacement, assumptions about acceleration, and the initial speed of the motorcycle.
  • Conceptual clarification, Assumption checking, Problem interpretation
  • Participants are questioning whether "distance" refers to "displacement" and if constant acceleration is assumed. They are also exploring the implications of the motorcycle changing speed every four seconds and the ambiguity around the initial speed.
There is an ongoing exploration of different interpretations regarding the problem setup. Some participants suggest methods for visualizing the data, such as using a step function or bar graph to represent average velocity, but no consensus has been reached on the initial conditions or definitions.
Participants note potential translation issues affecting the clarity of the question. There is also uncertainty about the data provided, particularly regarding the initial speed and the meaning of distance in the context of the problem.
Sh4dman
A distance-time graph has been given, and I'm required to draw the v-t graph (question has been added with attempt at solution as a picture. It's question d of no.2.) I've added my answer but I don't know if it's correct or not.
s = vt
s = (u + v)t/2
Question:
Answer:
Part d) is not clear to me. When it says distance, does it mean displacement? Does it assume constant acceleration in each phase of 4 seconds? Why would a motorcycle only change speed every four seconds? Is the starting speed zero or 2m/s? You can't tell even that from the data given.
Are these distances in each period of four seconds? Distance can never be negative, so that would make more sense.
I think by distance, the question probably means the total displacement from an initial point. Could be a translation error as english version questions are generally translated from our other language.
As for the question related to the initial speed, should I have started the graph from t = 4s?
I'd stick with what you have. One way to check is to do a step function or bar graph showing the average velocity for each period of 4 seconds. Your graph should bisect the bar graph at the midpoint of each bar. If that makes sense.
By midpoint of the bars, do you mean like the exact center of the bars?
Yes. That's another way to do the problem. Start with the "frequency polygon" and draw the velocity from that.
Although, I'd say: draw a graph of average velocity first and use that to draw the velocity graph.
Is this what you meant by the graphs bisecting?
