Velocity vector addition problem
The discussion revolves around a velocity vector addition problem involving a boat crossing a river. Participants are attempting to determine the correct angle and direction of the boat's velocity relative to both the river and the banks, referencing a specific exercise from "Pohl’s Introduction to Physics."
  • Participants discuss the vector sum of the boat's velocity relative to the banks and the river. There are attempts to clarify the relationship between the velocities of the boat and the river, with some questioning the assumptions about their magnitudes. Others express confusion about the correct angle and the implications of different reference frames.
The conversation is ongoing, with various interpretations of the problem being explored. Some participants have offered guidance on vector addition, while others are struggling with the concepts and calculations involved. There is no explicit consensus on the correct approach or solution yet.
Participants note specific measurements of the river's width and the distance along the bank, which are relevant to the geometry of the problem. There is also mention of language barriers affecting understanding.
evo13
Introduction physics
Vector addition
Hello, guys. Interesting riddle here.
I have no idea how to solve it. Tried different methods, but point is answer is always wrong,
exact answer Downriver, at an angle of 53.13(degree) to the bank.
That exercise is from
"Pohl’s Introduction to Physics"
The basic idea is that the velocity of the boat relative to the banks is the vector sum of the velocity of the river relative to the banks and the velocity of the boat relative to the river.
Yes, and i can't get a right answer. Basic idea is that velocity of boat and river is the same magnitude, at least as i understand it
Let's see your calculations.
PS The given answer of 53.13 degress is correct.
Sorry for the sloppiness, this is just one of the solutions I tried
You know that the river is ##600m## wide and it's ##300m## along the bank from ##A## to ##B##. The angle ##\alpha## can be calculated from this geometry.
I.e. ##\tan \alpha = 1/2##
You should get the answer from that.
Yep, i did that. ∠α is 26,565 degrees
AB = sqrt(45) is not relevant, sorry.
That gives you the direction relative to the bank. The question wants the direction relative to the water, which means you have to do vector addition.
Sorry but vector addition is second part of my solving attempt, below horizontal line.
I don't understand what else i can do
PS I don't see how you got 58.3 degrees. You should have got 63.4 degrees upstream as the direction relative to the bank. But, that is independent of the velocity of the river.
lets try another explanation, more clear i hope
Okay, I see what you've done. Why would ##a = b##?
Note that your diagram is based on the reference frame of the banks. It's difficult to indicate the velocity of the boat relative to the river on that diagram.
Vector addition is the way to go!
if not a = b, than c = b. Right?
I tried this also
I tried this also
Neither. Your fundamental problem is that ##c## is from the river's frame of reference and ##a## is from the banks frame of reference. You are mixing vectors from two reference frames in one diagram.
Even if these equations were to hold, they can't be shown in a single diagram.
Use vector addition!
Ye, alright. Thank for the help.
I am clearly not understand the question than, English is not my native.
You do understand the question. You're trying a clever shorcut that doesn't work!
  • · Replies 16 ·
  • · Replies 16 ·
