Verification of Green's Theorem
The discussion revolves around verifying Green's Theorem for the vector field F(x,y) = (2xy - x²)i + (x + y²)j, specifically for the region R bounded by the curves y = x² and y² = x. Participants are examining the integration process and the setup of the problem.
  • Participants discuss the integration of the line integral and the double integral, noting potential errors in the original poster's approach. There are questions about the completeness of the boundary integration and the correct limits for the double integral over the specified region.
Some participants have pointed out errors in the original calculations and suggested corrections regarding the integration limits and the path taken around the boundary. There is an ongoing exploration of the correct setup for the problem, with various interpretations being considered.
Participants highlight the importance of precise notation and the implications of using variables that overlap with those in the vector field. There is an acknowledgment of the need for clarity in defining parameters used in the integration process.
sunnyday11
Verify Green's Theorem for F(x,y) = (2xy-x2) i + (x + y2) j
and the region R which is bounded by the curves y = x2 and y2 = x
[tex]\int[/tex] CF dr = [tex]\int\int[/tex]R (dF2/dx - dF1/dy) dxdy
For [tex]\int[/tex] CF dr ,
r(t) = x i + x2 j
r'(t) = i + 2x j
0 to 1 [tex]\int[/tex] (2x3 + x2 + 2x5)dx
= 2/4 + 1/3 + 2/6
= 7/6
For [tex]\int\int[/tex]R (dF2/dx - dF1/dy) dxdy both integrate from 0 to 1.
[tex]\int\int[/tex] (1 - 2x) dxdy = [tex]\int[/tex] (1- 2x)dx = 1-1 = 0
I think I have made an error somewhere but I could not figure out where.
Thank you very much!
There are several errors. First, you have only integrated half way around the boundary- from (0, 0) to (1, 1) along the curve [itex]y= x^2[/itex]. You still need to integrate from (1, 1) back to (0, 0) along the curve [itex]x= y^2[/itex].
And the integration over the region bounded by those is NOT
[tex]\int_0^1\int_0^1 dydx[/tex]
That is over the square with boundaries y= 0, y= 1, x= 0, x= 1. To integrate over the given region, if you wish to use the order "dydx" then, yes, x goes form 0 to 1 but for every x, y goes from [itex]x^2[/itex] to [itex]\sqrt{x}[/itex]:
[tex]\int_{x=0}^1\int_{y= x^2}^{\sqrt{x}} dydx[/tex]
Or you can use the order dxdy. Then y goes from 0 to 1 while x goes from [itex]y^2[/itex] to [itex]\sqrt{y}[/itex]:
[tex]\int_{y=0}^1\int_{x= y^2}^{\sqrt{y}} dxdy[/tex]
And also be more precise in your notation. Don't use x for your parameter when that is already a variable in the original vector field. It makes no sense to write r(t) = x i + x^2 j unless x is a function of t but then you write x(t) instead of just x. Good notation is always best to solve a problem.
Thank you very much for your help!
I got 1/15 for both parts, so I just subtracted one from the other and got 0 which agrees with the other solution.
  • · Replies 105 ·
12K
  • · Replies 19 ·
