Stokes' Theorem Verification for Triangle with Given Vertices
  • Thread starter Thread starter c0der
    Stokes Theorem
The discussion centers on verifying Stokes' theorem for the vector field F = [y^2, x^2, -x+z] around a triangle defined by the vertices (0,0,1), (1,0,1), and (1,1,1). The initial calculations showed that both the surface integral of curl F and the line integral around the triangle yielded zero, while the textbook answer was 1/3. A participant identified that the area of integration was incorrectly defined and pointed out that the integrand, 2(x-y), is positive over the correct triangular region. The conclusion is that the theorem was verified for a different curve, highlighting the importance of accurately defining the integration area.
c0der
Verify Stokes' theorem for the following:
F=[y^2, x^2, -x+z]
Around the triangle with vertices (0,0,1),(1,0,1),(1,1,1)
\int\int_S(curlF)\cdot ndA=\int_C F\cdot r' ds
[/B]
For the LHS:
curlF\cdot n=2x-2y
\int\int_S(curlF)\cdot ndA=\int_0^1 \int_0^{1-x}2x-2ydydx
This gives zero. Also integrating over the three curves of the triangle gives zero. However, the book's answer is 1/3. Any idea what the mistake is?
F=[y^2, x^2, -x+z]
[/B]
For the LHS:
curlF\cdot n=2x-2y
First of all, the area of integration is wrong. The triangle is bounded by the line x = y, the x axis, and the line y = 1.
Second, in this area, the integrand is 2x - 2y = 2(x-y). For the entire area, this is positive (except for at the boundary x = y, where it is zero). The result must therefore be positive. Try drawing the points (in the x-y-plane, the z-coordinate is constant) on a piece of paper. In the region you have integrated over, the integrand is antisymmetric with respect to x=y and the the area is symmetric with respect to this and should therefore give a zero result.
In short, you have verified Stokes' theorem, but for a different curve.
Thank you, stupid me.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 26 ·
