Verify that the sum of three quantities x, y, z
The discussion revolves around verifying that the sum of three quantities x, y, z, whose product is a constant k, is maximum when these quantities are equal. Participants explore the implications of the problem statement and the conditions under which the maximum occurs.
  • Participants express confusion regarding the interpretation of "maximum" in the context of the problem, with some suggesting it may actually refer to a minimum. There are discussions about the application of Lagrange multipliers and the conditions for maxima and minima in multivariable functions.
The discussion is ongoing, with various interpretations being explored. Some participants have offered insights into the mathematical techniques relevant to the problem, while others question the assumptions about the values of x, y, and z, particularly regarding their positivity.
There is uncertainty about the constraints on the variables x, y, and z, particularly whether they are required to be positive. This affects the conclusions drawn about the maximum or minimum of the sum.
Elias Waranoi
Verify that the sum of three quantities x, y, z, whose product is a constant k, is maximum when these three quantities are equal.
w = x + y + z
k = x * y * z
Assuming that my understanding of the question is correct i.e. that we want the maximum of w and x*y*z has to be equal to a constant k then I'm pretty lost. If they mean the maximum as the largest value of w possible then it's definitely not when x = y = z.
If k = 1 then if x = y = z would give w = 3. But if k = 1 and x = 100, y = 0.1, z = 0.1 then k is still 1 and w = 100.2.
If they mean maximum as in where the rate of change of w is 0 then that doesn't make sense either because even though the rate of change of w is 0 when x = y = z, w is at it's lowest so that would make that point into a minimum.
The only thing I can think of is that they wrote maximum instead of minimum.
Haven't you seen the method of Lagrange multipliers?
Never heard of it. I'm working with the Calculus made easy book and I haven't encountered it there.
What kind of techniques have you seen/used to solve these types of problems?
This chapter was the first and only chapter on partial differentation. They showed that to find the maxima and minima of a multivariable function, the derivative of all partial derivatives have to be zero.
w = x + y + z
k = x * y * z
You are right. The sum should be minimum.
Ah, sorry, I missed that, I thought they were asking for a minimum.
w = x + y + z
k = x * y * z
The result is true for a minimum sum. There is no maximum sum under those conditions, because we can write the sum as
$$S = x + y + \frac{k}{xy},$$
and so can have ##S \to +\infty## by taking ##x,y \to 0+##.
In that case, k = xyz, w = x + y + z = k/(yz) + k/(xz) + k/(xy)
∂w/∂x = -k/(x2z) - k/(x2y) = -y/x - z/x = 0 ∴ y = -z
∂w/∂y = -k/(y2z) - k/(y2x) = -x/y - z/y = 0 ∴ z = -x
∂w/∂z = -k/(z2y) - k/(z2x) = -x/z - y/z = 0 ∴ x = -y
Now this confuses me, because y = -z therefore x = -y = z. Now I have x = z and z = -x? Am I allowed to do this?
I tried testing with values and w doesn't even seem to be a minimum when x = y = z considering that if x = 1, y = -1, z = -1 then w = -1
What
w = x + y + z
k = x * y * z
constraints do you have on x,y,z ? Are they positive?
Now this confuses me, because y = -z therefore x = -y = z. Now I have x = z and z = -x? Am I allowed to do this?I tried testing with values and w doesn't even seem to be a minimum when x = y = z considering that if x = 1, y = -1, z = -1 then w = -1
Please use the appropriate reply button that identifies which post you are replying to. I cannot tell what you are commenting on in your response above.
For non-negative values of ##x,y,z## the point ##(x,y,z) = (c,c,c)## (with ##c = k^{1/3}## and ##k > 0##) really is a provable minimum.
However, if you allow for some negative values of the variables, the sum has no finite minimum for the same reason I outlined in #8 above: you can have
$$S = x + y + \frac{k}{xy} \to -\infty$$
by having ##x \to 0+## and ##y \to 0-## (again, when ##k > 0##).
