Verifying a Hard Trigonometric Identitiy ()
  • Context: High School
  • Thread starter Thread starter Harleyd2900
    Hard Trigonometric
11 replies · 7K views
Harleyd2900
My Pre-Cal teacher gave us this problem today. I have worked on it for a very long time and have goten no where :confused:. I was wondering if anyone had any ideas on how to do it, or even where to start. I started it myself with using the pythagorean idenities for the left side, then the difference of square; however after that I didn't know where to go.
cos²5x - cos²x = -sin4x x sin6x
Thanks a lot for your help,
Edit: (Damit... sorry I think I posted this in the wrong place)
Are you sure that's true?
It's kind of impossible. Because as x goes to infinity the left side remains contained in a small range, where as the right side blows up because you are multiplying by x.
Jason,
I think that is a multiplication sign and not the variable x.
Harley,
HINT: Write the left side as
[tex](\cos 5x - \cos x)(\cos 5x + \cos x)[/tex]
Tide said:
Jason,
Harley,
Good hint. I see the difference of squares. Should I factor out a cosx now?
BTW that x is a multiplication sign... sorry about that.
No, you don't want to factor out a cos x.
Do you know any trig identities involving [itex]\cos a - b[/itex] and [itex]\cos a + b[/itex]?
Yes I know both of thoes. Thoes can be used on [tex](\cos 5x - \cos x)(\cos 5x + \cos x)[/tex] ? Whouldn't a cosx have to be on the outside of the () in order to use it?
cos(5x)= cos(4x+ x)= cos(4x)cos(x)- sin(4x)sin(x)
cos(4x)= cos(3x+ x)= cos(3x)cos(x)- sin(3x)sin(x) and
sin(4x)= sin(3x+ x)= sin(3x)cos(x)+ cos(3x)sin(x) so
cos(5x)= (cos(3x)cos(x)- sin(3x)sin(x))cos(x)- (sin(3x)cos(x)+ cos(3x)sin(x))sin(x)
= cos(3x)cos2(x)- sin(3x)sin(x)cos(x)- sin(3x)sin(x)cos(x)- cos(3x)sin2(x)= cos(3x)(cos2x- sin2(x))
etc.
etc.
You lost me.:eek: :confused:
Whould this bring me anyware:
cos²5x - cos²x = (-sin4x)(sin6x)
(1-sin^2(5x)) - (1-sin^2x) =
It's basically the answer minus two-three steps.
I'd recommend to go through it all step-by-step. Write them all if you have to.
Hmm,... have you learned the following identities:
[tex]\cos \alpha + \cos \beta = 2 \cos \left( \frac{\alpha + \beta}{2} \right) \cos \left( \frac{\alpha - \beta}{2} \right)[/tex]
[tex]\cos \alpha - \cos \beta = -2 \sin \left( \frac{\alpha + \beta}{2} \right) \sin \left( \frac{\alpha - \beta}{2} \right)[/tex]
[tex]\sin \alpha + \sin \beta = 2 \sin \left( \frac{\alpha + \beta}{2} \right) \cos \left( \frac{\alpha - \beta}{2} \right)[/tex]
[tex]\sin \alpha - \sin \beta = 2 \cos \left( \frac{\alpha + \beta}{2} \right) \sin \left( \frac{\alpha - \beta}{2} \right)[/tex]?
Back to your problem, we have:
[tex]\cos ^ 2 (5x) - \cos ^ 2 x = (\cos (5x) - \cos x)(\cos (5x) + \cos x)[/tex]. Now with the 4 identities above, and the double-angle formulas, can you prove that [tex]\cos ^ 2 (5x) - \cos ^ 2 x = - \sin (4x) \sin (6x)[/tex]?
Can you go from here?
The key is to change the right hand side:
cos²5x - cos²x = -sin6x.sin4x
So cos²5x - cos²x = -sin(5x+x).sin(5x-x)
then expand and simplify the rhs.
The rest is:
- sin4x.sin6x = - (sin5x - x).(sin(5x + x)
= - [(sin5x.cosx - cos5x.sinx).(sin5x.cosx - cos5x.sinx)]
Tip #3, Difference of two squares
= - (sin²5x.cos²x - cos²5x.sin²x)
= - [(1 - cos²5x).cos²x - cos²5x.(1 - cos²x)]
= - [cos²x - cos²5x.cos²x - cos²5x + cos²5x.cos²x]
= - (cos²x - cos²5x)
= cos²5x - cos²x
= LHS
Q.E.D.
The tip numbers refer to trig proof tips in an article I have written,
http://math.suite101.com/article.cfm/trigonometric-identity-advanced-example
Good luck,
