Verifying Bessel's Differential Equation
The forum discussion centers on verifying Bessel's differential equation using the Bessel function defined as f(x) = \sum_{k=0}^\infty \frac{(-1)^{k}x^{2k+1}}{2^{2k+1}(k!)(k+1)!}. The user calculated the first, second derivatives, and substituted them into the differential equation x^2y'' + xy' + (x^2 - 1)y = 0. Despite combining terms and simplifying, the user struggled to achieve a zero numerator, prompting questions about potential errors or further simplifications. The discussion highlights the importance of correctly shifting summation indices and combining terms to verify the equation.
  • Understanding of Bessel functions and their properties
  • Familiarity with differential equations, specifically Bessel's differential equation
  • Knowledge of series expansions and summation techniques
  • Proficiency in manipulating infinite series and factorials
  • Study the properties of Bessel functions, particularly their applications in solving differential equations
  • Learn about shifting indices in summations to simplify complex series
  • Explore techniques for verifying solutions to differential equations
  • Investigate additional examples of Bessel's differential equation and their solutions
Mathematicians, physicists, and engineering students who are working with Bessel functions and differential equations, particularly those seeking to deepen their understanding of series solutions and their applications.
taiello805
Hey everyone, I am trying to use the Bessel function:
f(x)= \sum_{k=0}^\infty \frac{(-1)^{k}x^{2k+1}}{2^{2k+1}(k!)(k+1)!}
To verify the Differential Equation:
x^2y''+xy'+(x^2-1)y=0
So I thought this was going to be really easy, but I am having some difficulties. First I calculated y,y',y'' to be:
y= \sum_{k=0}^\infty \frac{(-1)^{k}x^{2k+1}}{2^{2k+1}(k!)(k+1)!}
y'= \sum_{k=0}^\infty \frac{(-1)^{k}(2k+1)x^{2k}}{2^{2k+1}(k!)(k+1)!}
y''= \sum_{k=0}^\infty \frac{(-1)^{k}(2k+1)(2k)x^{2k-1}}{2^{2k+1}(k!)(k+1)!}
And then I just pluged those into the differential equation to yield:
x^2 \sum_{k=0}^\infty \frac{(-1)^{k}(2k+1)(2k)x^{2k-1}}{2^{2k+1}(k!)(k+1)!} + x\sum_{k=0}^\infty \frac{(-1)^{k}(2k+1)x^{2k}}{2^{2k+1}(k!)(k+1)!} + (x^2-1)\sum_{k=0}^\infty \frac{(-1)^{k}x^{2k+1}}{2^{2k+1}(k!)(k+1)!} = 0
Then I just put the x terms in the summation since they are constant to get:
\sum_{k=0}^\infty \frac{(-1)^{k}(2k+1)(2k)x^{2k+1}}{2^{2k+1}(k!)(k+1)!} + \sum_{k=0}^\infty \frac{(-1)^{k}(2k+1)x^{2k+1}}{2^{2k+1}(k!)(k+1)!} + \sum_{k=0}^\infty \frac{(-1)^{k}(x^2-1)x^{2k+1}}{2^{2k+1}(k!)(k+1)!} = 0
And since the summations are all indexed the same and all have the same denominator, I combined them to one summation with one fraction:
\sum_{k=0}^\infty \frac{(-1)^{k}(2k+1)(2k)x^{2k+1} + (-1)^{k}(2k+1)x^{2k+1} + (-1)^{k}(x^2-1)x^{2k+1}}{2^{2k+1}(k!)(k+1)!} = 0
But now that I have one huge fraction, after all the simplification I have done, I can't get the numerator to zero out since the DE is homogeneous.
Did I make an error in my calculation? Have I done everything correct, but there is even MORE simplification? And if so, can you help me? Or am I just approaching this problem completely wrong?
Thanks a TON!Tony
You should have expanded the term:
\left(x^2-1\right)\sum _{k=0}^{\infty } \frac{(-1)^kx^{2k+1}}{2^{2k+1}k!(k+1)!}
into 2 terms:
x^2\sum _{k=0}^{\infty } \frac{(-1)^kx^{2k+1}}{2^{2k+1}k!(k+1)!}-\sum _{k=0}^{\infty } \frac{(-1)^kx^{2k+1}}{2^{2k+1}k!(k+1)!}
You shift the index, and combine it again.
I did that at first, but I thought that would'd help at all. Expanding that, putting the x's in the summation and then combining, I got:
\sum_{k=0}^\infty \frac{(-1)^k(2k+1)(2k)x^{2k+1}+(-1)^k(2k+1)x^{2k+1}+(-1)^kx^{2k+3}-(-1)^kx^{2k+1}}{2^{2k+1}(k!)(k+1)!}
But that still looks like it is going no where. The numerator doesn't look like it is zero, unless it is really cryptic and I am not catching it. Help?
You didn't do the shifting of the summation variables. You should do the following:
\sum _{k=0}^{\infty } \frac{(-1)^k(2k+1)(2k)x^{2k+1}+(-1)^k(2k+1)x^{2k+1}+(-1)^kx^{2k+3}-(-1)^kx^{2k+1}}{2^{2k+1}k!(k+1)!}
\sum _{k=0}^{\infty } \frac{(-1)^k(2k+1)(2k)x^{2k+1}+(-1)^k(2k+1)x^{2k+1}-(-1)^kx^{2k+1}}{2^{2k+1}k!(k+1)!}+\sum _{k=0}^{\infty } \frac{(-1)^kx^{2k+3}}{2^{2k+1}k!(k+1)!}
Do the shifting in this step:
\sum _{k=0}^{\infty } \frac{(-1)^k(2k+1)(2k)x^{2k+1}+(-1)^k(2k+1)x^{2k+1}-(-1)^kx^{2k+1}}{2^{2k+1}k!(k+1)!}+\sum _{k=1}^{\infty } \frac{(-1)^{k-1}x^{2k+1}}{2^{2k-1}(k-1)!k!}
Grouping it together again:
\sum _{k=1}^{\infty } \frac{(-1)^k(2k+1)(2k)x^{2k+1}+(-1)^k(2k+1)x^{2k+1}-(-1)^kx^{2k+1}+4k(k+1)(-1)^{k-1}x^{2k+1}}{2^{2k+1}k!(k+1)!}
You should be able to show that it is indeed zero.
Ah, I see. That is indeed zero. Thanks a MILLION! However, I am a little fuzzy how you went from your 3rd to 4th step in your last post. I understand that you let j=k-1 to shift the end summation, but how were you able to recombine it back with the first summation when that one was indexed at k=0? I don't know if this is a stupid question, but that transition from step 3 to 4 just doesn't look natural to me.
Since I take out the k=0 term, and it is again zero! I just skip a bit.
AHH! I see. Duh. Thanks soooooo much! :D
