Verifying Logarithms Homework: Get Help Here
  • Thread starter Thread starter Tommzar
    Logarithms
The discussion revolves around verifying a logarithmic equation involving both logarithm and natural logarithm expressions. The original poster presents the equation log(1/2xy^2) = ln x + 3 ln y - ln 2 and seeks assistance in understanding how to approach the verification process.
  • Participants discuss combining logarithmic terms on the right side into a single expression and question the consistency between the use of log and ln. There is also exploration of the properties of logarithms and how they apply to the given equation.
The conversation is ongoing, with participants providing insights into logarithmic properties and questioning the original problem's clarity. Some participants suggest that there may be a typo in the problem statement regarding the coefficients of ln y, while others emphasize the need to clarify the equation's format.
There is uncertainty regarding the correct interpretation of the logarithmic terms, specifically whether to treat log and ln as equivalent or different. Additionally, the original problem statement appears to have inconsistencies that participants are attempting to address.
Tommzar
i have been trying for hours on with next to no results even just an insight on how to go about it would be helpful
Do you know how to combine the terms on the right side into one logarithm expression?
Also, you have used log and ln. Do you intend for these to be different-based logs?
vaguely yes
and yes well from the criteria sheet that is what it reads
this is what i got by combining the terms on the right ln(xy^3/2)
vaguely yes
Then you'll need to study the properties of logarithms, and particularly what ln a + ln b equals.
After you do that, we'll help you with the rest.
i think there is a typo on the original criteria sheet as it reads 3 ln y when combined this = y^3 so I am thinking that it should be 2 ln y
if so i think i have figured it out if not I am still stumped
I don't know anything about your problem sheet, but 3 ln y = ln y3
so therefore the whole right hand side would = ln(xy^3/2) where as the left = log(1/2xy^2)
so where it says 3 ln y it should read 2 ln y
i think i have got this now thanks for your help mark :)
If you are supposed to verify that the given equation is true for all reasonable values of x and y, the question is not well stated, for two reasons: the 3 ln y vs 2 ln y that you mentioned, and log on one side and ln on the other. These mean different things. If I understand the problem, it should be given with one or the other, but not with both.
I still do not know what is your equation.
Is it:
[tex]log(\frac{1}{2xy^2}) = ln x + 3 ln y - ln 2[/tex]
or is it
[tex]log(\frac{1}{2}*xy^2})=ln x + 3lny - ln2[/tex]
You still need to use the fact that
ln y + ln z = ln (y*z)
and
ln y - ln z = ln(y/z)
Is it:
or is it
> [tex]log(\frac{1}{2}*xy^2})=ln x + 3lny - ln2[/tex] <
and
The highlighted one is the equation i needed to verify
[itex]ln((1/2)xy^2)= ln(1/2)+ ln(x)+ 2 ln(y)[/tex]. Is that the same as the right side?[/itex]
right i actually remembered how to do this alls i had to do was expand the left side to show it = the right side
  • · Replies 19 ·
  • · Replies 21 ·
