Veronica's question at Yahoo Answers (determinants)
  • Context: MHB
  • Thread starter Thread starter Chris L T521
    Determinants
The discussion addresses the calculation of the determinant of the expression \( \det(A^{-1}+4\text{adj}(A)) \) for a \( 3 \times 3 \) matrix \( A \) with \( \det A = 2 \). By utilizing the relationship between the adjugate and the inverse of a matrix, the adjugate is expressed as \( \text{adj}(A) = (\det A)A^{-1} \). Substituting this into the determinant expression leads to \( \det(9A^{-1}) \), which simplifies to \( \frac{729}{2} \) using properties of determinants. Thus, the final result is established as \( \det(A^{-1}+4\text{adj}(A)) = \frac{729}{2} \).
  • Understanding of determinants in linear algebra
  • Familiarity with the adjugate and inverse of matrices
  • Knowledge of properties of determinants, including scaling
  • Ability to manipulate matrix equations and expressions
  • Study the properties of the adjugate matrix in detail
  • Learn about the implications of the determinant in linear transformations
  • Explore the derivation and applications of the determinant of the inverse matrix
  • Investigate advanced topics in linear algebra, such as eigenvalues and eigenvectors
Students and professionals in mathematics, particularly those studying linear algebra, as well as educators looking for clear examples of determinant calculations involving matrix inverses and adjugates.
Hi Veronica,
We can express the adjugate $\text{adj}(A)$ in terms of $A^{-1}$ by using the formula \[A^{-1}=\dfrac{1}{\det A}\text{adj}(A)\implies\text{adj}(A)=(\det A)A^{-1}\]
From here, we substitute this into $\det(A^{-1}+4\text{adj}(A))$ and use the fact that $\det A=2$ to get the following:
\[\begin{aligned}\det(A^{-1}+4\text{adj}(A)) &= \det(A^{-1}+4[(\det A)A^{-1}])\\ &=\det([4(\det A)+1]A^{-1})\\ &= \det([4(2)+1]A^{-1})\\ &= \det(9A^{-1}).\end{aligned}\]
Now, we use the fact that if $M$ is a $3\times 3$ matrix and $c$ is a constant, then $\det(cM)=c^3\det(M)$. We also recall that $\det (A^{-1})=\dfrac{1}{\det A}$.
Thus, we now see that
\[\begin{aligned}\det(9A^{-1}) &=9^3\det(A^{-1})\\ &=\frac{729}{\det A}\\ &=\frac{729}{2}.\end{aligned}\]
Therefore, if $A$ is a $3\times 3$ matrix with $\det A=2$, then $\det(A^{-1}+4\text{adj}(A))=\dfrac{729}{2}$.
  • · Replies 20 ·
